my guess is that when I have less than 200mb free on my 32gb card it tends to do funky things when flashing roms. Cause if I try to copy something over to the micro sd and it has less than 200mbs on it, its extremely slow to process that. Stupid card... anyways great job devs. Looking forward to the next update
Reflashed it and now its running smoothlymy guess is that when I have less than 200mb free on my 32gb card it tends to do funky things when flashing roms. Cause if I try to copy something over to the micro sd and it has less than 200mbs on it, its extremely slow to process that. Stupid card... anyways great job devs. Looking forward to the next update
Oh yeah is there anyway to get the music to show on the lock screen for controls? I'm using the apex launcher. Thanks![]()
Ok, so I got the Deep Sleep problem fixed and that should be in the next build whenever that is.
Also, I think the wifi autoconnect issue should be back to the way that it was in 0.6.5. So if you weren't having a problem then, you should be back to normal and if you were having a problem then, then you'll be back to still having a problem.![]()
I have done factory resets and all and it seems to work fine at first then it just stops. I also drop 3g and cell service and have to reset with airplane mode still. no worries though it will work itself out eventually.Ok, so I got the Deep Sleep problem fixed and that should be in the next build whenever that is.
Seeing Pixels
New CM9 music app. You have to install it manually but it has lockscreen controls on my phone.
DInteresting.
If I use the youtube app and play any video, it plays at like 1fps unless I turn on HQ, then it plays fine.
I did upgrade from 0.6.5, so I'm going to try a full wipe and see if that makes a difference.
although Chrome works best.
when connecting to wifi I notice that I sometimes don't get the blue color on the wifi signal. Anybody else getting this? And it sometimes auto connects when it wants to.
one other question, can we get or does open mic work? It would be really cool for the open mic voice recognition worked, but I guess it might require special hardware or something
Really? My Chrome doesn't seem to work at all. As far as I can tell it isn't redrawing the browser canvas on screen. I can open/close tabs etc but the canvas is always the same. Thankfully I still enjoy using Dolphin.![]()
I now this is noob question guys but since we are building off cyanogenmod anytime they update their ROM by adding new preferences or tweaks it's built into out rom,correct?
Anyone else have two "gallery" apps after the update? When I look in Root Explorer I see Galaxy4.apk, Gallery2.apk, GalleryGoogle.apk. Also I see the MusicFX.apk but can't find an equalizer in the music app.
Just a heads up
