FroyoShark
Wow... I can really notice a difference in performance now that OC is working
Awesome, google voice typing works![]()
I don't know if this bug has been reported or not but after flashing alpha 0.6.6.
The phone wont go to deep sleep, tested with cpuspy.
other then that this build runs smooth.
With this build, I have been experiencing random freezes and reboots. I have wiped my battery stats to see if that had any effect. Haven't had another one yet, but just wanted to see if any other users have had this issue.
I have not. If you still continue to get that, I'd suggest that you do a complete wipe data/factory resest in CWM and then reflash the ROM afterwards.
Is anyone else phone almost never clocking down on 6.6.? I'm pretty much sitting at 1024 all the time. Using interactive and sio. Only thing really running is Skype.
Edit: also not deep sleeping with wifi off.
Edit 2: also wifi not auto connecting
This is fresh install
I'm seeing the no deep sleep problem with wifi on and off, but CPU spy shows me sitting at 245MHz most of the time.
I wiped cache and dalvik cache as I usually do when installing a rom over the same one and now it seems a bit sluggish... never had that problem before. I will try it again in a bit. Anybody else seem to experience this sluggishness with the rom?
Not at all. .6.6 is amazingly fast and snappy for me. Only problem is that it is not going into deep sleep, but Mantera will be looking into that.
wtf? When i flashed 0.6.6 is deleted my Apex launcher which was installed in /system/app. Is this a mistake or intentionally getting us to use Trebuchet launcher????
(I did not have this problem going from 0.6.4 to 0.6.5 with apex installed)
This is supposed to happen. You must have been doing something differently if Apex was still installed after upgrading to 0.6.5. My guess would be either you previously had it installed as a non-system app, or you manually inserted the APK into the rom zip before upgrading (this is what I do).
