Some notable stuff that was just recently committed upstream by CM:
CM9 Theme chooser
Ability to add apps and customize the lockscreen ring
I am noticing that it is considerably taking much longer to charge the battery with new ROM. Anyone else notice this or it's just me.
the next alpha build
make sure you dont have the kill battery functions on....wifi, bluetooth,gpsI have noticed this also. I have switched over from MIUI where it didn't take long at all to charge the battery. But on this ROM it takes quite a while.![]()
Did it work
I have problems with soft keys no matter what ROM I use
Does anyone know if encryption in the settings menu work now for update 6.13.3. Its not listed as working nor not working
Mantera i am a legal adviser/IT. i would like to know if i could help with the camera fix for cm9?
What are the odds of bringing in contact options like there are in MIUI? I'm giving the miui 4.0 rom a shot, and i really liked being able to remove all the duplicates and condense them down into one contact. also, only showing contacts with phone numbers is nice as well.
Hey Mantera I'm just wondering are you going to release the new upstream stuff that has the Lockscreens and Themes with it. Or is there no need because the themes probably wouldn't work on the Triumph?
Sorry about that, its in the security part under settings option. Near the part that says lock screen. When phone is charged, it says don't stop encryption but its not doing anything
thank you soo much u a life save for the camera on cm9 im soo happy to hear thatmantera i am a legal adviser/it. I would like to know if i could help with the camera fix for cm9?
I have upgraded my Triumph from 6.11 to 6.13. I have noticed that the back lighting on the soft keys at the bottom of the device no longer works. Additionally, since I went from CM7 to CM9, the Google Maps App shows all of my distances with the Labs Measure tool in km instead of miles.
