Trying it now.So has anyone played with Sarin Gas Kernel with this ROM?
That big android exploit, giving full remote access.. I heard cm fixed it.. But is it fixed in this current build?
The MMS thing is weird. I send 2 out once a day with wifi on and wifi off just for testing and never run into any issues other then bothering my friends by sending them pictures of my desk and asking for a picture in return. The only time I had an MMS not go through was 3 or 4 builds ago when CM had broke the app and had used that older replacement app to flash in recovery. Actually that's not true, I sent one to G60's Victory and he replied his MMS had not been working on Victory stock and he was going to call VM about it but other then those 2 have had no problems. Had just sent and received one with wifi on just before I decided to write this post.
Edit: Also my Associated Press app isn't working, although this isn't detrimental, it's probably my favorite source for news. Could someone else download it and see if it'll connect to the internet? I've been reading reviews and no one else seems to be having problems. I've noticed that this rom breaks apps. The only thing that I can expect the culprit being is that it IS on 4.2.2 and that's the latest and greatest, hence compatibility issues. If that's the case then I'll just have to wait for an update to the app.
It's called AP mobile? Looks like a good app if it worked. If you look at the reviews, many one star reviews share this problem.
I recently started using feedly for news and I love it.
I updated 2 days ago, I also see the WiMax issue. It turns off if it loses connection. I thought it was the Service in my area 'til early today.Has anyone else had wimax issues with new update? Thought maybe it had been sarin kernel so refreshed rom but still have connection problems. One other oddity: my lockscreen doesn't come up any more. If i sleep it with s2w or the power button either one, when I bring it back up it goes straight to the home screen. I have checked I don't seem to have disabled the lockscreen anywhere.
Using stock messenger, how can I get the menu options like Read/Reply/Delete on the status bar notification?
I remember seeing something to enable/disable that in system settings, i'll get back to you on that..You don't have that? My angry bean does. Something might not be right.
I wish I could delete emails from the status bar.
Is anyone having problems with Google Maps flickering like crazy? I thought it was just Navigation at first, but it's Maps too. Starts happening after just a few moments. Other GPS apps are fine. I tried deleting cache, uninstalling and reinstalling already.
There's a thread about this, but I'll respond here as well... this is probably not a rom specific issue. The problem looks identical to the issue that we used to have with the Chrome app. That problem was fixed in the beta version of Chrome a few months back, but I have no idea if it was ever fixed in the stable version.
