Sweeeet
Is there any chance MHL is coming any time soon? I remember you saying you were tinkering with it. Got a smaller desk in my new apartment and wanted to set up my second monitor, which doesn't fit on the desk anymore, in the living room, do some mild emulation gaming through the phone.
Great work, going to report back on how battery life is doing with the new governor.
I have no complaints about the update. I installed it last night and everything just seems to be working so much better. I've had very few apps that force close, the keyboard will crash whenever I add something to the User Dictionary but it's only the first time I add a word each time I reflash. I get a random reboot every once in a while. So far only once on the current build.
Is thermald used at all anymore? I see from Kernel tuner that its been removed from the Kernel, and it is no longer started by the post_boot script.
Also found a bug with sweep2wake, when the home button is hit, the phone wakes up. I currently have sweep2wake on with no backlight. This happens when both Menu and Home are start keys. I noticed this because when I swiped to turn the screen off, the screen would turn off and then turn right back on. This is because when I swiped to turn it off, I hit the home key in the process and it turned back on. I don't believe this is usual behavior.
Did you do a full wipe? Because I have none of these issues at all?
I have a pioneer avic-z150 that has app-radio and needs the MHL to use the app-radio Yes it would be great if we could get MHL to work with that it would make this rom perfect.![]()
Yes it would be nice, if I can fix it I will. Unfortunately there is no magic Spell or MHL Wand to wave around why the Rom is compiling. At least that I am aware of at this point.
