SUroot
Extreme Android User
170 downloads for 1.4 now. Slowly but surely.
201.
Thats 30 in 24 hours. Not bad.
As an alternative to putting the APN data in by hand, I used an app called APN Manager to back up my APNs from CM7 and then restore them when I'd installed dGB.
I thought I'd got the APNs backed up with Ti, obviously not eh! I'll use APN mgr to back them up and go again.
I was also getting FCs when trying to select a wallpaper, but I did restore some system data with TI so it might have been that.
I'm going to stop the google thingy too.. Ti is prob going to be better me thinks.
2nd go, got the APNs sorted. All restored via TI. Still getting FCs though when I try to choose a wallpaper?
Already tried! full wipe, reflash, select wallpaper FC.
Managed to set one now through after installed gallery3d.
Anyone have a copy geniewidget.apk handy?
Is that why it FCs then?There are no real wallpapers so you need to select via gallery or zedge
Genie is that battery drain news widget
Dunno. I use go launcher, so if I long press homescreen and go to wallpaper, I get 3 options
1) Gallery - I use this
2) GO wallpeprs
3) Wallpapers - these are the built in ones, of which there are none. It brings up a black screen with Set wallpaper. If you "set wallpaper" where there aren't any, it will force close.
Whats that about notifications? I just use the ones that are default. got no issues there. What exactly happens??
i have the prokey version so it silent installsEg. Ti backup issues a notification for each app it restores during a batch. Couldn't stop it...
might be just a settings issue so don't want to sat its an issue yet. I'll have another flash tonight see if its better.
I'm maybe restoring thing incorrectly?
