Flashing kernels is easy: copy zip to card, flash and, er, that's it!
Flashing kernels is easy: copy zip to card, flash and, er, that's it!![]()
It is down to missing fonts. It's probably down to Droidsansfallback being replaced. It's a huge font 3.5 MB. I tried to get specific characters out of it but there are 100s of thousands which I just can't go through. I can supply the font if you want it
Cool on the /system then! My A2SD was picking to apps [Aldiko and Rocket Bunnies] that had moved them selves to my SD card. I've moved them back and now A2SD says "information not available".I only have 40k free now. Can't remember when that screen shot was taken. May be from before a font was added back in.
My a2sd shows things too. Unsure why.
HTH?
a2sd is not enabled on this rom. what ever values it mentions are invalid anyway
Yeh I know that, but Sus first QSI pic didn't show A2SD, so was surprised when mine did, even more so that it was listing apps using it.
But its sorted now![]()
I think qsi went shit. Shame was an easy way to tell if a2sd is working. Can't trust it now
A2sd yes, if you're happy with the 65MB system, I can supply the full fallback font which should display those chatacters.
I'm not sure on that ram tweak, it may work. I haven't touched any RAM stuff
I was a sweaty palmed lurker, until my first rooting yesterday.
I loaded and unloaded Oxygen, this, Gingerbread, Gingervillian, Honeycomb, and then back to this. This is where its at for me, skinny and fast.
Thanks SU' for your collaboration of FAQs, your ROM, and for making my first time so memorable.
So I wouldn't be able to use the provided Hboot if I use the full font? I haven't done custom mtd myself, so...u don't happen to have a proper hboot lying around somewhere?![]()
Oo er missus.
You're welcome.
I have 2 hboots, a 60 and a 65. It will fit in the latter.
Heres the font:
http://www.mattman.org/rootsu/rootSU/font/DroidSansFallback.ttf
