yes some of those apps fab left or gave us the ability to install/uninstall or switch through the scripts he built in ....gives us the best of both worlds.....as far as the battery let your battery charge to 100%....then go into clockwork recovery then go to advanced and you will see ,,,,,wipe batt stats,,,,select it and wipe them and that should help as well but only do this when your batt is up to 100%....there are other little tricks for battery life you will find all over the forums as well
My battery life isn't as good as it was before this rom so I decided to try what you suggested. I did as you said and my phone showed a triangle hazard sign with an exclamation point next to the droid guy. Then when my phone rebooted, my sd card was blank and my phone is asking me if I want to format it. Did I lose everything on my sd card?
