filipino808
Member
will the 4.2 camera work ?
Okay, I have come to the realization that the WiFi problem I'm having is simply that it turns off WiFi when the phone is in "sleep mode". I have tried all three settings on WiFi turning off during "sleep" but they all yield the same result where WiFi does not continue. I don't know if I'm the only one having this problem, nor do I have any idea where to start for fixing it if I am the only one.[/QUOTE
In WiFi Settings-Advanced, what is WiFi Always on set to?
The 300 MB of RAM wasn't actually "lost" - I did some research and found out that it's actually those 300 MB of RAM that we are running out of. The EGL libs don't allocate in the user space of 740ish MB of RAM; they allocate somewhere in the kernel region which is housed in that last 300 MB. It doesn't matter how much zram you have or whether there's 1, 10 or 100 MB free in user space; if there's no space in the PMEM area, egl crashes.
I don't want to make PMEM bigger and reduce user memory (which might OOM something else). I don't have time right now to test the egl libs that noseph posted, so would someone having game crashes make a backup and try flashing this (it's a slightly modified B2 with the libs switched out)? It may or may not boot; if it does, could you please report on whether the game crashes improve or get worse?
I'll flash it and see what happens
EDIT: Won't boot, after LG logo the phone turns off...
For those of you having WiFi or EGL crash problems, could you try this version and see if it makes any progress on your issues? I changed the kernel slightly and disabled the HDMI output framebuffer (1920x1080x2) to see if that frees up enough PMEM for graphics to run smoothly. I also partially reverted TDM's wifi patch to narrow down the particular line that could be causing the shutoff.
It booted on my phone, but you should know the drill about backups already.
Is there a way to increase the voltage to the cpu? I always reboot while using my maximum clock speed at 1674 and I think it is because of the lower voltage.
Is there another way I can get the most the most recent copy with all the foxes all the links are down
Emulating gameboy color and phone randomly reboots,not a problem with other games
This is probably the EGL problem. If you don't think so, a log might be helpful.
How do I pull a log?
Quick question- the op says that the front camera hangs recording video, is that also true with skype? Kind of a necessity at this point!
