[ROM][BETA] CyanogenMod 10 for the LG Lucid
You probably need to wipe cache and factory reset from CWM.
Already tried that(I cleared all Caches and factory reset from CMW but now only on the CyanogenMod boot animation), it's on the "CyanogenMod" boot animation with the spinning logo and well yeah. My Key Lights go on, it has not booted past that, how long is this supossed to take?
EDIT: Alright after trying all that one last time (all at once) it started sucessfully.
I just wanted to thank you, stcarlso, for finally allowing me to have JB on my Lucid. It is a great device and always wondered why it never got much love from the consumer. I have been loading CM on my android since my first HTC Incredible and while I am technical I have very little working knowledge of code particularly in the Android environment but I will share and hope it offers any help with the rebooting issue.
I notice that in the game I play, Hellfire, my device randomly reboots after approx 10-15 minutes of continuous play. While it does happen on occasion in other situations I would say 90% of the time it is within this game. This is the only 3d intensive application I use on this device. I found that if I exit to home every so often and then go right back into the game I am able to avoid the rebooting. I do not know if this is because of the OS cleaning up memory while app is suspended and then refreshing when I go back in or if the CPU is throttling down maintaining stability. Maybe there is a work around or 3rd party utility that can mimic this behavior without having to exit the application?
Anyways, thanks and keep up the good work, I look forward to B3!
I've been playing with B2 for a while and thanks. It's pretty awesome, fast, and it seems to support more apps (I haven't changed overclock settings yet). The only thing I really don't like is the crappy battery life, hopefully in B3 that will be fixed. Is there anyway to disable the front key light?
Having clocks at 1674 really chews battery. If you want more runtime, use the clock settings to change it back to 1188. For me, the ROM actually lasts longer than stock.
ive lost 4g:( and the method that i used to get it back was the kdz unbricker to put it back to stock then flash cm10 again, but it always wants to go back to 3g once i use this lovely rom again and again:(
I have no idea what is wrong with your phone... I have 4g almost all of the time and I usually didnt have 4g on the v6 basebands.
Ok after flashing this I'm stuck on the CM10 boot screen. About how long does it take to boot after a first install? Do I just do a battery pull and then do a wipe in CWM? Just wondering as it's been cycling for about 20 minutes now.....
Ok got that figured out finally. Now that I'm sufficiently brain dead, how do I go about added screen widgets? I used to be able to long press on the screen to add them but that just pulls up the wallpapers option...
You could use nova launcher. It works great on this rom
I installed B2 yesterday, and when I connect to my PC I cannot get to the internal storage. I can access it from ASTRO file manager (when not connected to the pc) but not from the PC. I dont use this partition too much, but it would be nice to copy to it from the pc. Any idea if this is just me or is it everyone, and is there a fix in the works?
Thanks
Phil
I have been keeping track of this thread for a while now, and I'm thinking about installing the ROM. Two questions would be 1.) How stable is the most recent version? And 2.) Is it any faster than stock ICS on the Lucid? Any improvements over stock? Thank you very much!
yes its stable and its way faster and smoother than stock ics rom
