[ROM][BETA] CyanogenMod 10 for the LG Lucid
So is this stable enough to flash on my phone for daily use?
Everything works fine except the two things on the front page?
Also, hows battery life compare?
Having clocks at 1674 really chews battery. If you want more runtime, use the clock settings to change it back to 1188. For me, the ROM actually lasts longer than stock.
Yep, worked perfectly, battery life is better and the ROM is faster.
This ROM is stable, I use it daily myself.
Those things are being worked on.
Battery life is better than stock.
Well, I went into Superuser, the changelog said 3.2, I checked the version, 3.1.4, the highest Superuser version is 3.1.3, so why is it 3.1.4?
I did try changing it, Superuser crashed everytime, I had to reinstall the ROM to fix the issue.
Hmm to me, all of the steps are pretty clear. So far so good, on the last step of downgrading to GB
Says that I succeeded in downgrading yet my phone is stuck in a bootloop with the 4GLTE and rings flashing on and on. Any help?
Can you please let me know what steps you take that may not be clearly stated? Don't want to mess up my phone!
1. Downgrade your LG Lucid to Gingerbread using KDZ.
2. Root the device while on GB. (If processes keep stopping hard factory reset your phone).
3. Install the ROM Manager app from Google Play and install ClockWorkMod (CWM).
4. Download the B2 ROM, Gapps and Baseband V8 for thr Lucid and put it on your external SD card.
5. Boot into recovery via ROM Manager.
6. Choose "Install ZIP from SD Card" (Use Volume buttons to navigate and power to select).
7. Install in this order:
- The LG Lucid CynaogenMod 10 ROM (On first page)
- GAPPS (On first page)
- Baseband V8 (Look through the thread for it)
8. In Recovery Mode do a factory reset and wipe your cache.
9. Reboot device in Recovery Mode.
10. Wait for it to boot and enjoy. (It will goto the LG Logo then CynaogenMod screen then it'll turn on)
Never heard of a bootloop there, try reinstalling GB in download mode.
Trying it again may work.
I've made a video about this ROM, mostly about features and such. Go on Youtube and search "xXApocalypticKillaXx" and search through my video for that. Just a little preview if you're skeptical qnput installing the ROM.
Hmm, been stuck on CyanogenMod boot screen for quite some time, so I took the battery out and trying again. I waited a good twenty minutes with nothing happening.
Go into recovery mode. Find a factory reset, do it, then find a "wipe cache" thing, do that and reboot, should work after that. I had the same issue at first, I did a factory reset and wiped all caches, then rebooted, it worked fine and still is working fine.
Well I just finished making two how-to videos for those having trouble and everyone who needs them! The first video came out good, the second not so great, I may remake it in the future. Check out my playlist for the videos here.
Hope this helps anyone who needs it!
Also I have made a written guide: http://pastebin.com/k6v2kMnR
Please forgive me if this has already been discussed and fixed, but I have an issue. After two days of the 4GLTE working, it seems to have stopped. I now only have 3G for some reason. Any ideas as to what's wrong? I'm in perfectly good 4G coverage.
I'm assuming that you went into network settings and enabled 4G. Does toggling airplane mode or rebooting fix it?
