Mattecko77
Just tried both, issue is still present.
I changed the Network Mode to "LTE/CDMA/EvDo/GSM/WCDMA" doing a speed test now (LTE is on), says 3G, checking if the slow connection issue is fixed.
Edit: I've tested, it's still slow, that max consistent for a few seconds is about 25kb/s, which is very slow.
Issue persists after reboot and airplane mode [toggling on/off] (I did turn off WiFi while testing).
All that changed after reboot was the Network Mode, I changed it back.
Yeah I've had the same issue. I only connect to 3G, in places where I would get 4GLTE. The 3G speed is incredibly slow, also when will B3 be released?
Are you running the ZV8 baseband? If not, try upgrading to it. If so, try a backup and clean wipe to see if the 4G comes back. A log pull might be helpful if none of these do anything (see instructions in the FAQ post if you're not sure how to pull a log). I have never had a 4G issue and so can't reproduce or fix the issue without some kind of log.
Sorry for a double post, but shouldn't following
[GUIDE] Unbrick LG Lucid
wipe my phone?
Just did it and it booted back up as before... trying to see if its still rooted.
Have to mail it tonight.
I don't have a backup. I have a stock firmware which I rooted.
I followed that guide step by step, and it didn't give me an out of the box OS like I was expecting. Its like it reloaded the system but not the personal data?
I was on V8 and used that guide to go to V8. Should my phone be wiped or no?
Seems like its not rooted now but I want to be sure.
One question I have about this rom before I try it out-
you all know on stock how easy it is to turn on and off data in the notifications bar? Is there anything comparable to this in the ROM?
Cool thanks I'll have a look.
If the 4g problem can be fixed I'll definitely try this out.
Still might anyways.
One question- can CWM and stuff be undone? Like if I do this, can I undo it all simply by reflashing stock?
Or is CWM permanent?
I personally haven't had a problem with 4G at all with this ROM.
Is it 100% reversible?
Like uninstall CWM and the mod and revert to how it came out of the box?
edit- bluemeany- did you used to have a tc?
