to get back to stock Rom and lost cwm does flashing do it ?
If you didn't make a Nandroid backup, the KDZ Tool can revert you back, so no worries.
so if I want to revert to return the phone I can just use the kdz to remove cwm and everything?
sweet!
screw you all from giving me a project during finals. (kidding) will be doing this tonight.
thanks everyone!
So to clarify. I'm on v8.
So use kdz tool to v5, root, install cwm, flash rom using cwm, flash baseband and apps using cdm, done?
What option do I hit for baseband and apps?
Did I leave any steps out?
what option do I hit in cwm? Never used it before
Also, why's that order matter? Will do though.
can't view right now. what zip do I install?
thought you meant another. does it need to be in the zip to flash?
Its downloading all my apps now!
Can't wait to remove all the junk ones from OEM rom! MWahahahaha.
Thanks guys, sure I'll have more questions!
Thanks!
It seems faster.
Battery seemed to die faster on phone, but I want to give it one good cycle to see first.
As far as GPS, I haven't tried it, but is there a more guaranteed fix yet?
So here's my next attempt at fixing EGL. Only flash this if you are having reboots during games or other graphic intensive operations and are willing to pull logs (FAQ post) if it fails. Once again, make a backup in case it fails to boot. No guarantees that it works as I haven't had the time to flash it during final exams.
Strange, I've never crashed before...
