LickeyMong
I'll pull hopefully pull a log tonight I have a soccer game so I probably will be busy,but i am still having the problem where my phone hangs on the boot screen and I have to wipe cache
After flashing cyanogenmod 10 (B2 and A3) i cant get the phone to connect in debuging mode, i am using the drivers i was using with the stock rom.
any suggestions.? i am runing windows 7.
Did you enable USB debugging in the settings menu? The drivers are the same as the stock ROM. The ROM is already rooted so you don't need to enable debugging for root access anyways.
I enable usb debugging, i do need the phone to connect on debugging so Q
pst or Dfs Cdma, programs like those can se the phone on a Port.
any other suggestions?
I have another phone (exactly the same (lg Lucid)) That one is stock, that one can connect on debugging mode when the Vzw Utility application is open, if not it dosen't go on debugging mode, I try to do the same with the one with cyanogenmod and it does not wants to go on debugging mode.
have you tried adb devices to see if its connected, because it could work without the icon in the notification drawer. If that is not working you can set persist.adb.notify to 1 in your build prop and that should work
Am i supposed to flash/install all of these one by one in order?
- B2 (most recent): cm-10-20130331-UNOFFICIAL-vs840.zip view plaincopy to clipboardprint?
- md5sum: 90e0927c5d4d52bb2a282e118b801cb1
- Google Apps for all versions: gapps-jb-20121011-signed.zip
- B1: cm-10-20130320-UNOFFICIAL-vs840.zip view plaincopy to clipboardprint?
- md5sum: 1f84151f998a89d9fc6edac40637b9f3
- A3: lucid_rom_a3.zip
- A2: lucid_rom_a2.zip
- A1: lucid_rom_a1.zip
Wildarc5737474 said:Am i supposed to flash/install all of these one by one in order?
just saw your video on YouTubeNo, flash B2, then GAPPS, then the LucidVZ8Baseband![]()
How do I flash the zv8 baseband?
Still not working!have you tried adb devices to see if its connected, because it could work without the icon in the notification drawer. If that is not working you can set persist.adb.notify to 1 in your build prop and that should work
i just noticed the internal memory of 4 gigs in the stock rom is around 1.4-1.5 gigs in this rom, did it disappear?
Yup. But I believe it is being worked on.
The "internal memory" stat on the apps page is misleading, as that is the system partition's size. The actual 4gb internal memory partition is mounted and writable, but does not show up in the storage screen (it is on /storage/sdcard1). I will work on a fix once egl has been hashed out or proved impossible to fix.
do we have any sort of fix for the ram issue yet. i just put b2 on my girlfriend's lucid and she does a lot of gaming(mostly candy crush saga and TR2) and it reboots quite often, also, i have had problems with hangups at the bootlogo, resulting in me hard rebooting. it usually happens every couple times the phone boots, and it can be annoying(and she gets scared because she thinks the phone is going to blow up every time it lags lol). any support at all would be very appreciated. thank you
u would need to pull logcats for him to see the problems
well thats a tall order right now... im on the daily builds on a strictly linux computer and i reinstall all my drivers daily... so im assuming that i just need to minimize ram usage for now until this problem has a universal fix. other than this minor(for me at least) issue, this is an excellent ROM. i thank stcarlso and everyone here for all the hard work. the lucid is a darn good phone for being "mid-grade hardware". looking forward to perhaps getting JB 4.2.2 or perhaps a stable version of Ubuntu Touch when it becomes available. sorry i cant use ADB right now, but i give my full support.
Excuse my inexperiance in this.
I downgraded to GB sucessfully then rooted my Lucid. I put CMW on it and recovery mode was working fine.
Then I installed the B2 ROM, Gapps, and finally the V8 baseband. When I install the ROM, I choose the "reboot system now" option and it stays stuck on the LG logo, please help.
