Def Logics
https://developer.qualcomm.com/mobi...phics-optimization-adreno/tools-and-resources and this maybe of some use
Huh. Who wants to test that? Very easy to do!
Id test it but need my phone/alarm to wake me up in the morning for work and not enough time to fix it before bed if it fails
It appears to run fine, I haven't had any problems a couple minutes after booting.
See any differences?
Were you having crashes before? That'd be the real improvement.
It was crashing during games before if I spent too long in them without switching apps. That was the first thing I tested as well, it still crashes with the patch, but it seems that it might take longer to crash. I will need to test more before I can make a definite statement on that. On another note, X-Plore File manager seems to be more responsive now.
Does anyone know of a Adreno 200 GPU phone with an official Jelly Bean 4.1 ROM? I'm looking for sources for a driver pull to fix EGL.
Thank you so much, would you be able to find the Lucid 2 Camera app?
Yeah I have it, but I'm not using my computer right now I'll have to do it later.
LU6200 is rumored to get jb soon. Don't know which version and it's just a rumor right now.
Here's another test version with graphics drivers pulled from CM10.0 for the Galaxy Note GT-7000 (also MSM8660 with Adreno 2XX). Maybe this will improve the EGL issue. It appeared to boot with a screen, but you all should know the drill about backups by now. (The link is the same as an older graphics test version but has an updated file.)
Isn't that going to just keep the CPU running at higher levels?
Hopefully it works., I'll test it soon. Currently I'm testing to see if this app (Safe Charge) will fix the issue if anything. Also thanks for your hard work in trying to get this ROM 100% working properly AND for just making it.
Safe Charge Google Play Link
Testing now...first boot touch screen didn't work, sometimes It's lag, I locked the screen, then it wouldn't light up (As well as the keys). So I pulled the battery, touch screen works and lock/unlocking screen is fine. After that, I uninstalled an app, then the screen froze, I locked it, wouldn't unlock and the keys were lighting. A random reboot occured. Restoring the backup I made before installing this ROM, it's pretty bad.
Sounds like you need to wipe cache. This version wasn't meant to fix sleep of death, it is an attempt to fix the reboots during game play.
So about the Camera app, any fix/replacement?
Can I get someone to try this?
If you take your phone, and using volume buttons turn it up, then turn it down all the way, does the bar go all the way to the beginning? Or one away still?
For me it won't go back all the way where silent and vibrate should be, resulting in my phone ringing even when its on vibrate. Yet if I go into settings I can manually slide it all the way over.
