filipino808
Member
https://www.dropbox.com/s/7dgfugerl34mywu/Baseband-Lucid-V8.zip
Flash this zip for new Basebands/modems
from ICS V8
flash this in recovery ? What does this zip do?
from ICS V8
Thanks for pointing that out, fixed. That's what I get for skimming the CyanogenMod about page instead of reading thoroughly.
I downgraded to gingerbread on my lucid to flash CWMR, but I can't get wifi working and I get no service. I have CWMR downloaded and pushed to my sdcard. How would I manually flash that recovery image onto the lucid? I would like to try this rom, but can't get CWM to work.
Are you able to boot into recovery? If not, http://androidforums.com/lucid-all-things-root/533930-root-one-click-root-lg-lucid-4-18-12-a.html
This is where you need to flash the ROM
or permission denied. any ideas?[*]
[*] LG Spectrum Root Exploit (Windows version)
[*] by Dan Rosenberg (@djrbliss)
[*] Before continuing, ensure USB debugging is enabled, that you
[*] have the latest LG drivers installed, and that your tablet
[*] is connected via USB.
[*] Press enter to root your phone...
Press any key to continue . . .
[*] Waiting for device...
* daemon not running. starting it now *
* daemon started successfully *
[*] Device found.
[*] Rebooting device...
[*] Waiting for device to reboot...
/system/bin/sh: cannot create /data/local.prop: Permission denied
[*] Rebooting device again...
[*] Attemping persistence...
remount failed: Operation not permitted
failed to copy 'su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
link failed Read-only file system
I've got the recovery flashed, but now it says error mounting sdcard in cwm recovery. It seems I can no longer continue. How do I fix this?
I do have the lte where I live though
Did you notice the issue on the ZV6 baseband/modem? If anything, ZV8 should help your issue as it puts a little more power into the radio than ZV7 or ZV6 to "increase call clarity" as stated in the rollout description. I haven't switched yet but have had minor to no issues with the ZV6 firmware. Unfortunately I don't use the lucid enough to determine any noticeable difference in 4G/3G reception.
Clear cache from gallery appIs there anyway to switch back to the rear camera after trying to get to the front facing one?
https://community.verizonwireless.com/message/791572#791572I didn't have any issues with zv6 . I'm also getting an occasional
text from 6250 saying VZMNM:1
I had this issue for a while, but it inexplicably fixed itself. I tried a clean wipe, among a few other things. What worked on the early spectrum builds was to flash back to stock gingerbread, enable gps, get a lock, then flash to CM10. Do either of these approaches help you?
