I haven't had any issues with my 4G, In fact I haven't seen 3g at all... One question for you... I have seen lock screen gestures as a feature for Cm but I can't find it anywhere..
everything works well but can you fix the internal 4g sdcard
it can be seen under the system setting storage and root explorer
but can not be used or store anything
I'll look at it and put it in B1, or make an A4 if it's really a deal breaker. When I tried it, I could open it in a root explorer and see/modify files on it, but it doesn't show up in system storage since I'm not sure exactly how to modify /system/etc/vold.fstab properly. A stock ICS ROM rip of this file might be handy now to set this one straight.
dev_mount sdcard /mnt/sdcard 30 /devices/platform/msm_sdcc.1/mmc_host/mmc0/mmc0:0001/block/mmcblk0 nonremovable
#dev_mount sdcard /mnt/sdcard auto /devices/platform/msm_sdcc.3/mmc_host /devices/platform/msm_sdcc.1/mmc_host
#dev_mount sdcard2 /mnt/sdcard/external_sd auto /devices/platform/msm_sdcc.3/mmc_host
dev_mount extsdcard /mnt/_ExternalSD auto /devices/platform/msm_sdcc.3/mmc_host
[*] LG Spectrum ICS Root script (Windows version)
[*] Copyright (c) 2012 jcase
[*] Roots the ICS Upgrade for the LG Spectrum
[*] Before continuing, ensure USB debugging is enabled, that you
[*] have the latest LG drivers installed, and that your phone is
[*] connected via USB.
[*] Press enter to root your phone...
Press any key to continue . . .
[*] Waiting for device...
* server not running *
* daemon not running. starting it now *
* daemon started successfully *
[*] Device found.
adb server is out of date. killing...
rm failed for /data/vpnch/vpnc_starter_lock, Permission denied
[*] Rebooting...
[*] Waiting for reboot...
/system/bin/sh: cannot create /data/local.prop: Permission denied
[*] Rebooting again...
'#' is not recognized as an internal or external command,
operable program or batch file.
[*] Installing root tools...
remount failed: Operation not permitted
failed to copy 'su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
link failed Read-only file system
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
failed to copy 'busybox' to '/system/xbin/busybox': Read-only file system
Unable to chmod /system/xbin/busybox: No such file or directory
/system/bin/sh: /system/xbin/busybox: not found
[*] Cleaning up...
rm failed for /data/local.prop, No such file or directory
[*] Rebooting one last time...
[*] Root complete, enjoy!
[*] Press any key to exit.
ok- here's my take on A3 - working smoothly, everything running fine
- My front camera will flip the picture in the gallery after it's been taken.
- When plugged in to my aux port, I'm having intermittent issues - every time a new YouTube video is played, i need to unplug and plug the aux cord back in... nothing big, but gets kind of annoying.
- The Bonnaroo official app crashed when I try to load the Roo Radio portion of it.
- Hot Schedules has an error every time I try to log in using the correct credentials.
Battery problems...
Android OS taking up 50%
It lasts about half a day and I have the extended battery...
I have no idea
Is there a way to get the three navigation buttons as a regular jb device?
cm10 is running very well on my Lucid, but id really love to experience Ubuntu Touch OS. but i dont have $400 for a nexus. anyone want to help get a thread going and kick this thing out?
you talking about the on-screen nav buttons? Yes they can be enabled, but its takes up even more of a already small screen. Those are really for devices w/o hardware or cap buttons like the Galaxy Nexus and tablets.
i would wait to experience Ubuntu touch. While it looks very nice, nothing works, most of the apps are just pictures of what they may look like, and while they have it running on spectrum, there is no network (3G, 4G, and connection), bluetooth, and wifi is iffy.
the only working parts are that i've seen are the notification draw, phone/sms and web browser.
I can't wait for a stable build of Ubuntu Touch. I'll donate any assistance I can to get that on the Lucid when it comes out.
I tested out the Wifi direct app. This ROM worked w/out issue in client mode. But when I tried it in server mode, the ROM rebooted, twice.
I am only getting 3G on this phone. I ran a speed test and only was getting 1 MB down.
