PlayfulGod
Extreme Android User
PG isnt sure eitherThe spectrum ROM has the same issue, so it didn't magically fix itself. It appears to be a CM10/CM10.1 problem as shown in this post from the spectrum forums. I'd love to fix it, but I don't have another phone to test it on. Would you mind running "adb pull /proc/last_kmsg > kmsg.txt" immediately after the WiFi Direct crash with the phone plugged in on USB?
There are two people here not getting 4G. Could you go into the Mobile Network settings (More... under the settings drawer) and check the Network Mode? Mine is set to "LTE/CDMA/EvDo", try that and "LTE only" and see if you can get any 4G signals. It could be a baseband problem; the ZV8 flashable zip might fix the issue. If all else fails, try backing up, factory reset, waiting 5 minutes after it boots to the home screen, and seeing if you get 4G.
As a note, we should be able to use the same kernel for CM10.1/AOKP42 as the CM10 build according to the Quattrimus JB spectrum post. Unsure as to why PG couldn't get graphics to run.
lolEDIT: Actually its doing what you described the lucid doing in the beginning, get the LG logo, then blank screen with just the backlight. Up to a certain point (my guess is the os finishes booting) I can get a adb logcat, which looks good, then adb gets shut down when the 4.2 adb shyt kicks in. cap buttons give feedback for a bit then it seems to lock up with the backlight still on.
