Hi all and thank you stcarlso!
I followed wiisixtyfours instructions on how to flash CM10 and have got everything working and looking great. Just want to make sure I have it as updated as it can be. So far I started out by downgrading to GB using ZV5 used the most recent B3 and gaaps files.
Is this as updated as I can be? I seen some people talking about V8 baseband should I update to this if so how and where is the file?
Thanks
The rom is CONSTANTLY freezing. Or either or tells me that whenever I try to install an app I don't have enough space. Really annoying! Back to stock I go sadly![]()
Thanks. That fixed it giving it another chance. Does active know when b4 or cm 10.1 is coming out? My mom is giving me her LG spectrum in March![]()
I cannot get B3 to install at all with CWM touch recovery. It errors with bad signature, and then after I disabled sig checks it errored with bad file. Any help?
I've followed the instructions from wiisixtyfour to flash GB, root the phone and install CWM Recovery. But now when I try to flash CM with CWM it says:
Waiting for SD card to mount (20s)
Waiting for SD card to mount (19s)
Timed out waiting for SD card...
Continuing anyways. Verifying SD Card marker...
SD Card marker not found...
Error processing ROM Manager Script.
I'm using the internal SD card and not the external one. Could that be the problem? I've already formatted everything and done a factory reset. Also I can access /sdcard from Root Browser. Any ideas how to fix this?
Just opened ROM Manager now and it said that I needed to mount SD Card for it to work. It didn't say that before...
Just had two random reboots for no apparent reason. Does anyone know how to fix it? I reinstalled the ruin and got no reboots for about a day. Then it just did it this morning lol
How do you access USB Ethernet mode with this?
I've had it on my phone for quite some time now. Only problem with it is the occasional lockup - black screen and pressing the power button does nothing. Have to pull the battery and then it sometimes hangs on the CM10 screen (screen turns off and 15 to 20 minutes later the CM10 screen is still on - another battery pull) sometimes it takes two or three battery pulls to finally get it to start. It loves to hang occasionally when you remove apps and sometimes when turning bluetooth on (I just leave it on now but on a reboot I have to be sure there are no bluetooth items on in range or it will sometimes hang on the animation screen again).... Just wondering how progression is going on the updates as I haven't been on here for awhile....
I have a similar problem. If I reboot the phone, it gets stuck on the cyanogenmod logo. The only way to workaround the issue is to wipe cache every time I reboot.
Has anyone had any overheating problems? On my phone if I play a game, or use the GPS, or just charging it while it is on, it will get really hot and if it gets too hot it just shuts off. It's rather inconvenient when using GPS and it turns of so I am no longer being directed.
I am using B2 and i set minimum clock speed to 384 MHz to prevent the Sleep of Death, and maximum clock to 1188 MHz. Not sure why it keeps happening, whether its the ROM or just my phone.
Is it a known issue that even the v8 radio within this rom doesn't get as good a signal as the stock ICS rom?
