xxwhynotxx
Could you make a ROM which includes this on the phone???
First, I'm not the dev.
Hello????
Second, people on forums don't usually reply in 15 minutes.
Hello????
I cant even root my phone, I try the one click root and it gives me this error. It keeps saying something in regards to read only file system every time I try to root my phone.
or permission denied. any ideas?
Pull a logcat while it is booting after about five minutes
My lg lucid freezes on the cyanogenmod circle thing??? any advice??
first off, SLOW DOWN. it can take up to five minutes to boot into the ROM after the initial install, and a logcat tells you what the OS is doing, and is usefull to see what is causing the porblem, it is part of the android dev kit
I've had times where it won't boot as well, and had to reset it. Another time or a two a wipe of cache cleared it though.
It's all good man!
Hey guys I found a rom that contains Beats Audio! I haven't flashed it yet! Do want to brick my phone or make it unuseful! Here is the link to the Rom. It also has 4.2.2 jelly bean on it. Its CM 10.1.
http://forum.xda-developers.com/showthread.php?t=2147407
Dude that rom is for an HTC phone, not an lg lucid..
I don't have this phone, so I can't be sure, but if front facing video is still an issue, you guys should look at media_profiles.xml... Editing that file will fix your problems..
I'm having having problems with my phone. First issue: I turned on the phone but the phone indicated that the SD card was damaged and had to reformat it. I reformat it. Second issue: I was turning on the phone but it froze on Cyangonmod circle.
Could anyone help me! I always the flash the rom everytime the cyanogenmod circle freezes.
Front camera video only doesn't work on the stock camera application.
Where exactly is this file located in /system?
There are problems with the LG rils during shut down. Try putting the phone into airplane mode before each power off.
Thanks bro! I will try that before shutting down! But what concerns is that the phone sometimes indicates that the SD is card is damaged and requires a format. When I do that the phone crashes, the phone boots and thats were the CM10 circle freezes.
Heres my number if want to text me, the number is .
