I'm having a similar issue where if the phone dies, when I go to plug it in it does the pulsing charge on the soft buttons and then goes to the charging screen as it should. The problem is that this only lasts for maybe 10-20 seconds...Then it shuts off. I have to repeat this process several times before it has enough power to start up on its own without the charger connected, and then after boot, reconnect the charger and it charges fine. This is the only problem I have had after 3 weeks of running. So great job carlo! Thank you for making the device usable again!
