xxwhynotxx
I'm not sure who's problem this is but I have had at least 2 texts in the last few days that were sent to me and I never received them.
I have issues with B3, occasionally it will freeze or lag and so I pull the battery and when I restart it it will stay at the bootlogo however it will lock/unlock, etc. but the screen only shows the bootlogo. I have to reboot into recovery using the button combo and then wipe the cache. Once I reboot it has to optimize all my 134 apps before it starts again. Not sure why that is.
Another issue is sometimes it freezes when connecting to wifi or phone network so I usually try to put it in airplane mode and then take it off airplane mode so it will connect all over again, however the airplane mode freezes the phone for a few minutes and then doesn't work.
Also, not a big issue but different from stock is the media transfer does not see the internal Storage, only external SD.
The first time I flashed b3 I had similar issues so I restored to a backup and refreshed without a wipe and everything works great now to this day, only issue is that ever since I flashed the 4.2 gapps everytime I reboot I come to android is updating/optimizing screen, any one have that issue or a fix for it?
Problem, 4G won't show, only 3G services. Google now won't talk to me back. I reflashed the ROMs and nothing happened... please help me with my phone. Lol
You're The Kid That Was Texting Me For Help Lol. You Try Going Into Your Data Settings?
Would it be safe to wipe both caches then flash this over?
Anyone?
Personally, I Always Wipe Both Whenever Flashing/Reflashing
I don't have the downtime at the moment to deal with reinstalling everything and stuff.
But if I can flash on top that'd be great since there are times where I don't have data when I definitely should.
You should not need a full wipe, but always back up...
I'm on B3, seems good!
Would this help our sms problem where it won't work over 1 page?
[SUPPORT] CyanogenMod 10 - Page 15 - Galaxy S III ROMs Q&A/Discussions - TeamUSCellular
Or what about extracting whatever relevant files from stock?
Stock MMS.apk caused an FC last I tried, but it might work now. You can try if you want. The MMS method should work but might cost the user, so I'll look into other methods first.
Here's The Direct Link To It : ***db.tt /HlrRSivf
Just Take The Space Out In The Middle. I Had To Put It In Because For Some Reason I Can't Post Links. Do A Factory/Data Reset, Wipe Cache, Flash The Rom, Factory/Data Reset Again, Wipe Cache Again, Then Reboot.
The broken out rom link is broken :-( is anybody able to supply me with an alternative link?
How do I install A2 into my phone???
The same as any other rom. Follow the guide that can be found in my Lucid Repository (see the post just above yours for the link).
Why do you want to use A2? B2 or B3 are much more stable.
My phone wont charge when its off.
