bigboy7525
Look up above - all sensors are broken at present. PLEASE READ THE FIRST POST.
Sorry about must a skip that part
So, I guess nobody else is having problems finding apps in the Android Market?
Am I the only one who's getting "Your device is not compatible with this item" more than usual?
http://imgur.com/H65nl.png[just install /IMG][/QUOTE]
Just installed it on my phone with out thunder working fine for me
Yea i cant download lightbox photos neither
Try the Thunderprop thing on the forum. I would think that should help.
I guess I'm not the only one.
There's a lot of apps that should work on the Triumph but don't. Lightbox was just an example of them.
I don't know about that.
tickerguy mentioned something in the first post about not messing with the build.prop, which is exactly what Thunderprop does.
I'm afraid I'll mess up my radio if I fllash the Thunderprop tweak.
If YOU sleep it (hit the power button) it will reliably wake back up. If IT sleeps, it sometimes does not, and the bad part of that is that it actually hard-locks somewhere in the kernel as I can't get a log from it. (The "you hit the button" was the part I fixed.) I'll eventually find that but it may be a while due to the rather "unique" circumstances of it dying. I suspect it's sensor or CPU power-state related which is why I'm not going after that first.
In situations like this (preview/alpha/beta builds) it's always wise to wipe everything.is it possible to update the previous rom with newer rom just by running the new rom. or do i have to wipe it clean and reinstall the new rom.
The problem with the lockups is that the phone is truly locked up when it happens - I can't plug it in and get into adb, which is going to make finding this a LOT of fun.
