Could I have a bad sd card? I have factory reset, re-flashed e (so its clean), re-root with 2nd_init recovery installed, then followed the instructions letter for letter and at step 11 when it starts its process it instantly stops with "bad file error". I have tried it with both downloads(your original and the one at Dev-Host).
Going to try it again with another sdcard!
no Gmail
edit: I guess I should have elaborated. There is no Gmail, and when installed it says the Service has stopped. Is their a work around for this using this rom?
I cannot provide details at this point but once you have good working set up of android kitchen, the kitchen will do it for you.
You just select option - deodexing and that's it
But setting up kitchen is little tricky because it involves with installing java and other stuff.
http://forum.xda-developers.com/showthread.php?t=633246
I tried to flash over c and I got the morning call error, and I tried it multiple times with both files so I know I'm not doing anything wrong.
Do not format /system
I got the Morning Call over c as well, so I flashed e and after I replaced sdcard it installed flawlessly.
Yea, this ROM is based on E firmware, so you must be running E.
I'll try that in a little while, is there any de-odexed version C around here?
Thank you for testing & confirming.
I will mention about firmware version (must use E) on OP
I really appreciate you guys testing with your own phone.
Anyway you could possibly de-odex version C for us please?
Actually I am thinking about creating a rom that works on all version of Firmwares. (I am not sure if it's possible or not..)
It seems like all firmware files are located @ /system/etc/firmware. Currently my rom contains those files in ROM making it heavy and conflicting with other versions.
I am going to make a rom without the syste/etc/firmware folder and check.
Enjoy your morningcall![]()
