Bionic Chronic
I am not sure if I did this right but this is the MD5 Checksum I got:I get "The application Swype (process com.swype.android.inputmethod) has stopped unexpectedly. Please try again" just constantly popping up. If I change input method in between pop ups it stops obviously but I'd like to keep using swype. Any ideas?
What i've done
First time around I did CWM backup, factory reset, installed v2 sprint, rebooted into system (started getting errors here), tried factory resetting in CWM and booting again, no luck.
Then I tried
factory reset, clear cache, install v2 sprint, clear cache, flash .2 hyper kernel, clear cache again, reboot into system (still getting error)
Right now i'm redownloading MBv2_sprint in case the download was off, do you have a MD5 sum to check against perchance?
Beyond that, any ideas? - thanks ahead of time
E629953A8128D310C92C47B221353558
Also you could try to uninstall Swype and reinstall it. Not sure though. Monster can confirm MD5 and give more insight as well to the Swype issue. As I was saying earlier If he can deodex the ROM or tell me how, than it will be much simpler. Sorry to make ya wait.
