Root [ROM][BOOST/SPRINT][ZVC]Marky Beats v2 beta[updated 7/30]
I've been using CTMod (and I love it in general) for my Sprint Marquee but the bluetooth issue is hard for me to overlook at this point.
How is BT behaving in MBv2 for those running it for Sprint? Everything solid?
I believe that BT is an issue on all available ROM's atm. Though I think Blood may have, or will soon, a fix for it in CTMod..
I dunno. The rooted stock that Blood posted worked fine as far as BT was concerned. Of course, that could be because it was essentially stock.
Yep. Worked fine for me until yesterday when I had a water incident with the phone. I only couldn't do BT phone calls with the CTMod ROM.
Hmm. I've had BT call issues with them all.. Odd. Then again I'm boost
Swyped from my LG-LG855 using Tapatalk 2 Beta-5
I'm running MB v2 w/1.2Ghz Hyper on boost and it has been working good on headset & file transfer. :)
It's seems like there must be a variation of manufacturers/IC's used depending on place/date built for the variety of outcomes that we are experiencing.
On Sprint, the LS855ZVC-M6600A-SCAUTSZ-3.0.40T baseband is not giving me data. Anyone else have this issue?
Also having erratic signal strength indicator behavior.
only time that happens is when batch installing a bunch of apps back at one time for some reason.
Re-flashed and once again my /cache wouldn't mount just like after the first time. But this time, I wiped it right away before I booted. Problem solved.
Something wonky going on with the cache partition after the installation (at least on my CWM)
I'm using CWM 5.0.2.8 - (based) recovery
it happens after installing the radio
ok i am incredibly confused. i have a boost marquee and did the zv4 update. then i followed the kbz reflash method and flashed to the sprint zv9 but still have a boost phone. under software on my phone it says ls855zv9. i have it rooted with cwm installed. would i be ok downloading the sprint version of mb and using cwm to install the rom?
Need a little help here guys i'm a newbie I flashed the murky beatsv2 I followEd instruction after rebooting back in can says error can't mount recovery cache,last logs, and when I reboot my phone its stuck at da lg screen any help would be greatly appreciated
Need a little help here guys i'm a newbie I flashed the murky "MARKY" beatsv2 I followEd instruction after rebooting back in can says error can't mount recovery cache,last logs, and when I reboot my phone its stuck at da lg screen any help would be greatly appreciated
You can try "wipe cache partition" in CWM.. see if that helps. If not maybe try "wipe data/factory reset" (You will lose your data with this option.)
__________________
Helpful? Hit Thanks :)
Hey just a heads up, (I'm running this rom right now so thanks, LOL) but the version of tapatalk installed is out of date and when you go to update it, it installs a second tapatalk and doesn't update the old one. So might want to remove it from the rom, and the equalizer is outdated as well... but you can upgrade that app.
Just out of curiosity, and this goes to the developer. Does this rom have the graphics unlocked? I know playfulgod's version had removed the limiter from the graphics, but I don't know if its unlocked in this rom... I don't this it is, but that could be me being paranoid, LOL.
Thanks anyways, great rom.
The beta expired, sorry
