Root [ROM][BOOST/SPRINT][ZVC]Marky Beats v2 beta[updated 7/30]
Hi guys, if i want to flash it back to stock rooted rom should i flash the stock kernel too or i can just leave it with hyper-v2.0 kernel ??
i got this msg when i click the link
Error (404)
We can't find the page you're looking for. Check out our Help Center and forums for help, or head back to home.
i just checked 3 different computers on 3 different networks, works fine. must be on your end
edit: U have to download the links from the original posts. Not the old versions. They are no longer on my dropbox. Dont try and dl those theyre non-existent. V2 is the one to dl
i'm sorry |Monster| i'm really new to the forum, could u give me link to OP for this one. thanks vmuch.
tried to do this to my marquee fresh out of the package. i first rooted the phone, second added to the lg driver to my computer, tried to run cwm recovery. this is where im lost. i can hold down the volume button and power at same time and access the android recovery menu and try to run the marky beats program from my sd card but it doesnt change anything after i reboot? im pretty sure my phone is rooted and in its original factory state. what step am i missing, or what ami i doing wrong?
addition, my service is thru boost and i downloaded the boost ZVC version of marky beats.
I don't think you Installed cwm recovery right or it would bring up a cwm when you hold volume rocker and power buttonmake sure when you run cwm you have all drivers installed USB debugging on and in charge only mode with no tethers running but after you do get I'm pretty sure you should get rom manager or something of the sorts to manage your roms
Installed Marky Beats v2 beta, did mms hot fix through aLogcat, still cant send mms on stock messenger. What am i doing wrong?
The easiest way is to download GooManager and click browse all files, then click devs, then scroll down to monster and browse all his files. Just double checked and everything is working this way.
i renamed the folder so it messed it up. Ill post a new link in the op
Uumm may I ask wat r hotfixes, cuz I need to fix an mms problem. I can't send multimedia messages so can anyone help thanks
