M
Member 893895
Guest
i believe so , only two of the pattern dots work which are in the top right corner
Well if after you factory reset the phone and you still get no response from parts of the screen then that's a hardware problem. I'm pretty sure it is so you're probably screwed unless your friend is gonna buy another digitizer to replace the broken one.
OH WOW! Tethering works! HA! They would charge for that normally!! oh wow this is so cool i can customize my icons and everything, would really like a skull icon for the battery level
