Chairshot215
Android Expert
Just a comment on how good the Battery life is with this Rom. I usually keep Wi-Fi off during work unless I’m using it for something work related. Today I forgot to turn Wi-Fi off from the previous night because when out and about later in the day because I will have plenty of power left for doing so. Will still keep Wi-Fi on but under Juice Defender control just too at least save a bit of power due to the phone not sleeping why WIFI is on, regardless if JD turns it off when idle but still better then it staying on all the time. Anyway before I start ranting I forgot to turn off Wi-Fi and as you can see from the shot below although I basically did not use the phone I would say this is incredible considering the amount of time the phone had been awake in that long a time period. If I remember correctly from the past even with this little use because Wi-Fi was left on I would be looking for a charger.
Edit: Before being pointed out 5000 times in the above post when referencing with WI-Fi left on I’m actually saying with WI-Fi in Juice Defenders control and am referring more to the time the phone spent Awake and what little power consumption that was used even why in this state.
