MediocreBadGuy
No problem, that's what WE as a community are here for.
I would like to return the Triumph to stock and reformat the sdcard as 1 partition.
Just flashed the 2-2 version and am having a problem. It has actually existed for awhile with reloaded cm7. My auto focus doesn't work...at all. When I'm on my MIUI rom install it works but not on CM7. Does anyone know of an adjustment that is having this problem or of a different camera app that doesn't have it? Thank you in advance.
hey whyzor! this would be a cool addition to cm7
do you think you could do it for all of us please?![]()
Can I copy the files on the sdcard to my computer, reformat the sdcard as one partition, recopy the files to the sdcard and be ok?
Last question tonight.
I only disabled autofocus for the CM7 video camera bc it was hunting all the time. The depth of field is large anyway. Regular camerashould still focus.
I'm encountering a weird issue. I'm in the Gallery looking at photos. When I enter into fullscreen mode to view a recent photo, it crops. But it has to be a recent photo I took after I installed 2-2-12. Any photo I took before the update will load up normally. When I go out into the thumbnail view the full image appears. I sent myself the image file and the file looks fine on my computer. Can someone confirm this?
I'm running ver. 2-2-2012 of TG-Reloaded with new kernel.
I have noticed the same thing but had assumed I had somehow muted the ringer![]()
Did you wipe cache and dalvik-cache before upgrading? I've never had this problem, try toggling some of the settings in Settings - CM Settings - Sound.
Regarding my issue with ringer volume going mute every few minutes.... I did wipe/data Factory reset first. Not sure if that is what you are asking. Sunday morning I spent a couple of hours fiddling with every sound setting I could find and nothing seemed to help. Then later Sunday I noticed the problem was no longer. I don't know what fixed. One other observation when the problem was happening was a single short press of the up volume would restore full volume from being muted.
The only other problem I noticed which has been reported previouly in this thread is that the cm setting input gets a force closed error.
I am very pleased with my phone and this CM7 ROM. I will probably stick with this ROM for awhile. Keep up the good work.
Tried rebooting?Is there a fix for the accelerometer? My home run Derby game is glitchy. The bat floats around and aiming is pretty much impossible. Sorry if this has been asked before.
I am still having issues with the dialer being slow. It has taken up to 3 minutes for the phone to place a call. I have even tried to call, placed dialed another number and it finally calls the first number. I have cleared cache and even reflashed but it eventually starts doing this again. Anyone seeing this?
Install QuickPic, it's way better than the default gallery app anyway.
Tried rebooting?
I have indeed tried rebooting. Should I wipe delvik and see if that works?
BTW thanks for a quick response
It uses original adreno gpu drivers. Last I heard the newer drivers don't perform any better, and even got less fps in some games.
Huawei Ideos X6 dev(edowar) have ported new GPU drivers to rom like CM7.2 from edowar & there device give double the performance in games and in NenaMark2
there device is giving about 24.9 fps with new driver compare orignal driver which gives around 13 fps in NenaMark2...!!
Anyone have a recommendation of a VOIP app other than Groove IP that works well with Google Voice on this build? I used to not have any problems with Groove IP but now I can call out on it but calls don't ring through to me. I have switched to where everyone calls my GV number but at work I have to run it over wifi due to having no cell signal.
Does anyone else have issues with the touchscreen acting like its not calibrated or something? It seems like it's off kilter. Also, it looks like the physical screen is rotated a little in the case. Maybe its just in my head?
