Root [ROM] CM7 TG-Reloaded (Final: 03-25)
I also noticed this when I flashed the update last night, YouTube app/YouTube mobile will not play videos. Pandora plays fine though. It could just be a problem with YouTube itself and not this ROM...will restore stock and confirm
Pandora works for a bit i think after i reboot and youtube flash videos on the broweser but then it stops working and hangs up :/ idk im gonna go back to my nandroid and confirm if its something with the ROM or not aswell.
Ok, I confirmed the 02-15 kernel has broken video (MP4/H264 codecs only apparently). It may have something to do with the extra BKL's I've implemented since the 02-08 kernel. I'll dig into this more when I have time, in the meantime if you need MP4 video working (including video camera), here's the older kernel:
WhyKernel-02-08.zip
Thanks Alot! I hope its not to much of a hassle to fix. And installing the kernal soley is just like installing an update correct? no clearing of cache or anything?
WhyKernel-02-08.zip
Thanks, this fixed the problem.
Adding 3rd party apps in means needing to support them (troubleshooting etc) within the ROM.
Thats exactly why I asked! Swype acts funnier than I think it should and I was hoping Whyzor would take a look at it! Sneaky...
What about the ICS keyboard ports? Is there somewhere you can direct me to get ahold of that?
Even if there is a problem found with swype, I can't do anything about it because I don't have the source code for it. So it's better to only include things that have a chance of being fixed.
Just do a search for 'ICS Keyboard' on the android market. I use the one by 'vllwp', it's lightweight, only downside is it needs internet permissions, which the dev said is for update checking, but I told him the market does it already and now it's 2 months since he made any updates, but the keyboard still runs update check code every time it starts up (bad practice). Oh well, I still use it, the other one is is by johntanmi, it's more bloated but works pretty well too.
I recommend getting in contact with the Swype devs with your issues. They will be able to do more about it than anyone here.
I can't change busybox versions for V6 Supercharger on the latest version. It says /system/xbin is not could not be mounted or something.
Just curious... What issues are you having with Swype? I keep trying keyboards and always return to Swype
I too would like to know. I currently run Swype and I have a few response issues, but again I believe that's due to hardware rather than the ROM.
Also- I can confirm both the video rendering issue with the Youtube app without the 2-08 Whykernel.
Post-installation of the 2-08 Whykernel allows for full video rendering.
Mine freezes up too... no luck with roms today
It seems like something with the kernel. I flashed the 02/08 kernel with the update (I wiped my old version) and the camera was working. I don't feel like going through the trouble of putting everything back onto my phone, so I'm going to try updating and putting the old kernel on my previous version.
Edit (again):
Yep, it's working now.
i dont have that problem and i just updated to the newest one also (new kernel too)
Are you using MP4/H264 codecs?
WhyKernel-02-08.zip
Ran Antutu this morning after flashing the new 2-16 Rom.
Then 3D scores went from 709 to 967. I'm running at 1024Mhz and total score is 3237. Something is better in this ROM.
I had a long wait in a doctors office and watched an AVI video. A few times sound went off and wouldn't come back on Mobo player. Resterted program skipped to where I was and it was okay.
Thanks again Whysor (wiser) You have done a great job.
Fantastic rom
It seems to have some video/audio issues
1. yelp first load animation stuck
2. youtube cant play videos
3. google music can't play music
Thanks
Was the camcorder auto focus feature turned off?
I noticed while recording that there is a noticeable clicking sound of the lens trying to focus which wasn't present on the stock rom. Just wondering.
Would you kindly read the posts above you?
If you flashed the most recent version of the ROM there are known video issues which can ONLY BE REMEDIED by flashing the Whykernel in the first post.
