TheDirectorFur
Is there an area here for overclocking questions for this ROM, which app to use and what are some safe settings?
Just download AdAway from the market. It will keep your host files updated and it's free.
I prefer to keep this a user-customizable setting rather than built-in default. In case it breaks some apps, the app developers need ads to support their work in their free versions anyway.
). Developers spend time developing their apps and I would assume most (if not all of them) would like a little money out of it even if it's just from the ads.I recently received a replacement phone that has the older hardware (seven bar codes). It replaced a six bar code phone. The touch accuracy works better on the older hardware phone, but (with TG Reloaded) i've had several random reboots and it just seems a little more schizo than the new hardware. Hopefully I can get a sixer the next time around!
From the time I swipe down and toggle WiFi in the notifications window, it takes about 20 seconds for the 3G icon to switch over to WiFi. Is this a known issue?
I think it's common. I've never been able to quickly connect to wireless after turning it on. Twenty seconds actually seems pretty quick, but I've never timed it.
Some people claim that if you actually go into the wifi settings (by swiping down and long-pressing the wifi toggle button) to turn it on it connects more quickly. It doesn't seem to help for me but it's something to try...
The ones I have are: Accelerometer BMA150, Bosch Sensortec
Comapss MS-3C Orientation, Yamaha Corporation
Magnetic field sensor MS-3C Magnetic Sensor, Yamaha Corp.
Proximity sensor LTR502 Proximity Sensor, Liteon corp
Light Sensor LTR502 Ambient Light Sensor, Liteon
I've decided to sell my Triumph and go back to the trusty old Optimus V until the next VM phone worth buying comes out (The HTC one V looks promising if the rumors are true). The MT's unreliable touchscreen gets on my nerve every time I use it and I can't stand it any longer.
I'll make a final build & test it on the phone before I part with it. It's been quite a learning experience for me the past few months, I'll stick with VM's $25/mo plan since nothing else can beat it for my type of usage. So maybe you'll see me on another VM phone forum.
BTW If anyone wants to buy my Triumph w/ everything that came in original box + an extra 1600 mAh battery (mint condition) + a soft & hard case, PM me. Looking to sell for $180 or more, first/highest offer will be accepted. Otherwise it'll go on ebay tonight. I'll update this post if it's been spoken for.
There is an update to CM7, know RC0 becomes RC1, I know lot's of thing's are already in this current version. But alway's great to have latest update...!!
Link Here For More Info :- CLICK HERE
Yes, this did seem to cut the time in half for me.
I understand that having WiFi on all the time prevents the phone from entering "deep sleep"? Has anyone tested to see how much the battery is drained having WiFi turned on over-night compared to just using 3G? I would like to have WiFi on while I am at work and when I am at home without the battery taking a big hit. Since I just got the phone a few days ago I haven't had the chance to test, but would be happy to do so.
I think I'm gonna cry...
You don't think you'll get agitated at the performance hit? What kept you from switching back until now?
