Whyzor why is this the final build? Helping with ics development?
Because everything has to come to an end... except maybe the universe, that may be infinite.
http://androidforums.com/4102036-post1590.html
Optimus V doesn't even compare, but whatever floats your boat.
Wow, I didn't like the Optimus V because the touch screen on it sucked, and I like the Motorola Triumph's screen... Maybe your device is faulty.. I don't know.
Thanks for all the Work Whyzor,
Does anyone plan on taking over? I can
If I remember correctly, you have to toggle on and off the wifi and use cpu spy to see if it goes into deep sleep mode again after turning screen off.
I tested using that method and it seems to be able to go back into deep sleep with TheOCv1.7.20 kernel. I'd like to see someone take Whyzor's latest kernel, revert the 2 sensor commit (like mantera did) so we can have the latest but still a working in-call sensor.
Basically going forward (if g60madman takes over), people should chime in when things work & also don't work with details, otherwise changes will be commited that could break things or cause complications.
I understand that CM7 for MT is final AS-IS with some issue still exist?
Other than Foyo 2.2 to GB 2.3(CM7), what are the advantages of Factory to CM7?
I just ordered me MT and want to see if it's worth it to loose one and gain one.
Can we dual boot like you could with HP Touchpad CM9 to webOS. Of course that's tablet not phone.
