Whyzor
Android Expert
I flashed mantera's OC kernel to try and fix the incall black screen. it worked for about 2 hours then had the black screen problem again
The term "black screen problem" doesn't distinguish between the 2 problems. 1 is if other side disconnects, the screen stays blank for a while and even power button won't bring it back. 2nd problem as some have reported, is when put to ear, the proximity sensor turns off the screen, but when the phone is pulled away again, it doesn't turn screen back on during the call. I have another attempted fix for the 2nd issue in the next kernel.
Will we still have the updated GPU drivers if we use a different kernel with TG-Reloaded?![]()
There are 2 parts to the GPU drivers update, 1st part is in the kernel, 2nd part is in the /system/lib/egl/ binary files. Both are included in TG-Reloaded ROM, any other kernel will have to have the new KGSL driver component (mantera's kernels is the only other right now that supports it).
