Is there a way to put gallery app onto the ROM so I can sync my Picasa photos?
Thx in advance
If you are talking about the stock Gallery, here it is. Put this on your sd card. Use a file explorer and go to where you put the apk. Tap on the apk and install it. Hope this is what you need.
Gallery3D.apk
Thank you. Works well.
Hey Blood a few post ago yous said that you will update the ROM with the relase of the new Kernel, will it have something new?
because there are a few things that would be good to add/change making the ROM near to perfection, like swipe to clear notifications, you just cant remove one and leave others, or remove all or don,t remove nothing.
Hey is Bluetooth broken? It fails me always D:
Can someone post the music apk just in case I deleted it lol
gonna be some major fixes in the next update, and some new features I ported from CM7:
Your still working on CT Mod? I thought this was your final release lol?
Good show Bloodawn!it was going to be but theres some bugs that needed fixed and couldn't just be patched, and I got bored.
so theres gonna be a final release part 2 when the new kernel is done =p
unfortunately fixing gapps in the rom so play services and youtube fully work would require a full wipe. but if your not worried about those you could just skip the new rom and flash the kernel when its done, then you won't have to redo everything.
Hey Bloodawn,
How can I tell if I'm using the latest kernel v?
Currently installed is 2.6.35.14-HYPER-GB.v3
BD@SS #12
Sadly, I've been experiencing these crushing slowdowns again, even after fresh install and cache/dalvik wipes. It usually happens after I've been using the phone over an hour. Hoping new kernel and final final rom will cure my woes!
heres the current build: http://androidforums.com/marquee-al...-beta-build-12-02-25-13-a-14.html#post5575735
OK, just flashed to 2.6.35.14-H4.BB12RC1+
BD@SS #12
Should I have cleared my cache/dalvik again?
Hoping this will help reduce the slowdowns... I'll be sure to check in and let everyone know how it goes.
One more question for you...
My GooManager periodically tells me (automatically) that there's an update for my ROM. (I currently have installed CTMod 3.75 Final so I'm not sure why I keep getting this notification). When I have check manually for updates (tapping the "check for updates" button in GooManager), it tells me that no updates for my rom were found.
I prefer to flash my roms from recovery anyway, not through software, so it's a moot point anyway. But I'm still curious why I keep getting a rom update notice.
