CTMod is a minimalist ROM designed for speed, stability and usability.
- Based on FG11
- Kernel: BobZhome's Kernel modified by me (init.d support added, optimized mounting, unsecured, cleaned up)
- ClockworkMod Superuser
- Busybox
- adb enabled at boot
- deodex'd, zipaligned, optimized and debloated
- Fully themed
- 14 widget Quickpanel
- Swipe to clear for notifications
- Extended Power Menu with Reboot, Hot Boot, Recovery and Screenshot
- DSPManager ported from CM7
- Downloadclutch
- Adblock
- and more
Added apps:
Make sure you have the latest ClockworkMod installed
Installation will wipe all your Data and Settings
Installation:
➯ Copy the zip to your sdcard
➯ Boot into ClockworkMod
➯ Make a backup!
➯ Select "install zip from sdcard"
➯ Select the ROM.zip
➯ Select "yes"
➯ After its finished press back
➯ Select "reboot system now"
Downloads:
(Boost) - CT3.80_SPH-M930BST.zip
Code:
[center]MD5sum: 0a34346e14d2fcbcb75beaeb131d4878[/center]
(Sprint) - CT3.80_SPH-M930.zip
Code:
[center]MD5sum: ca6b04ef3c60f6b4810a6c0a6d0b31ac[/center]
Old Versions:
CT3.75-TU-Boost.zip
CT3.75-TU-Sprint.zip
Code:
[B][SIZE="3"]Changelog:[/SIZE][/B]
[B]04/07/13 Version 3.80[/B]
Fixed SystemUI bugs (so it works with UOT)
Fixed charging images when the phone is off
Removed Voltage Control, Boat Browser, Stock Clock and SuperSU
Added Lightning Browser, MiClock and CWM Superuser
Rebuilt CTSettings (fixed some bugs and added CPU/I/O Control to it)
Updated gapps (fixed YouTube issues)
Updated File Explorer and QuickPic
Updated Busybox
Updated some of the theme
Updated the lockscreen a little
Updated font
New Settings layout
New boot and shutdown animation
Ported swipe to clear for notifications
Ported DSPManager from CM7
Ported animations from JB 4.2.2
Cleaned build.prop and init scripts
Performance and stability improvements
[B]12/6/12 Version 3.75[/B]
Redid the Power Menu and added Hot Boot
Cleaned build.prop and init.d
Fixed MMS for Boost
Fixed wallpaper scrolling
Fixed Calendar.apk
Redid Mms.apk to fix some bugs
Redid About phone > System update to just show Update PRL and Profile
New wallpaper
New loading bar
New settings layout
New wifi icon
New boot animation
Updated Play store, File explorer, Quickpic and Xperia to newest versions
Replaced Chrome with Boat Browser
Replaced Superuser with SuperSU
Removed a couple useless apps I missed before
[B]09/5/12[/B]
Added a MMS fix for Boost Mobile
[B]09/1/12 Verson 3.70[/B]
Switched the base to Sprint FG11
Most previous issues should be fixed (If the camera still gives you problems go to the Quickpanel settings and disable Flashlight, then go to Manage applications in settings and clear Camera data and reboot)
Updated GooManager to newest version
[B]08/26/12 Verson 3.69[/B]
Fixed the camera
Fixed QuickPic
Updated the ramdisk for FF27
Fixed the force-close when going to Settings > About phone > Status
[B]08/26/12 Verson 3.68 beta[/B]
Initial release for the Transform Ultra
