Root [ROM][CTMod]Nemesis 1.3
PhoneMan93
Nemesis
For EJ06​
Specifications:
Highly based off CTMod(Thanks Bloodawn)
KoumaKernal 1.0
Rooted
Boot Animations Enabled
Deodexd
AdBlock
RAM Op. Script
MIUI Camera
MIUI Music
Download Crutch
Pretty much a Modified CTMod....
I would like to say Thanks to:
Hroark-for helping me Deodex
Bloodawn-for CTMod
PlayfulGod-For all he helped with
Kouma- for the Kernal! :P
And Google.com for the rest :P
Almost everything is like CTMod.
It has a few less .apk's
The Only .apk's it has is:
Browser
MIUI Camera
Phone
Contacts
Messaging
MIUI Music
Settings
Market
Downloads
Most up-to-date SuperUser
My Files(I would replace with ESFile)
No Bluetooth Capabilities
I themed MIUI Music, MIUI Camera, and SuperUser.
My Custom Nemus Theme will take care of the rest of it.
Odin Version
The Odin version can be obtained here.
Flashable Version
Get NeMeSiS here.
1.)Place on SDCard
2.)Boot into CWM
3.)Backup
4.)Flash NeMiSiS.zip
5.)Factory reset
6.)reboot
Get my Nemus Theme here.
1,)right click the nemuslauncher.zip
2.)click Extract all...
3.)after extracted copy the regular nemuslauncher folder to your SDCard
4.)on your phone hit the menu button>Launcher Settings>Theme Settings>and its the one without a preveiw
SCREEN SHOTS WILL BE UP SOON!!
You sure it wasn't Blood or Hroark that helped you deodex?
I don't remember knowing anything about deodexing myself :)
Not that I don't appreciate being thanked, I just don't want to take credit for something I think I didn't do
Oh crap it was hroark! sorry no disrespect but i get yall confused a lot! idk y.
Well Thanks for the kernel! :) lol
I'm downloading and giving this a test spank now, hope all goes well. You said this is based off of CTMOD correct? Which version did you use to Dev this if you don't mind me asking?
Looks good so far, I'm gonna run Quadrant and see how well it does.
Edit: Quadrant scored 1146 after three pulls, AnTuTu scored 1799 on third pull and getting better as the phone adapts. :)
This is a wow rom. Really good work. I was planning on keeping the Alien Android Rom on my phone but this i think just changed my mind!
I would like to congratulate you on adding another Rom to the Library for everyone to enjoy. It works well for pretty much every aspect of the phone.
I am going to try it out tonight or tomorrow. You're moving right along with tools for us to use. I appreciate your hard work.
No themes from me except the Nemus Launcher theme in the oringinal post, college just started back up for me last week and i probably wont do anything else till spring break or so.
Like the theme. Power Widgets in notification and reboot options would be a plus. And for . some reason a lot of my games lag. They run smoothly on ctmod 2.4. Even wordfeud.
i installed this, doesnt have a way to change wall papers, play videos, or view pictures so far.. any help with this? i like everything else though
If you know how to add that stuff be my guest. I just don't have the time anymore. People love to put more stuff on you when they realize your struggling, I'm by no means saying you are putting more on me, it's just I work 10 hour days and go to school for 8 hours every other day and my trainer wants me to fight in a month... I'm sorry but this is the last of my releases for at least 3-4 months.
If you all need anything just pm me I'll be happy to help when I get the chance.
What EXACTLY did you do? If you installed only the live wallpapers.apk found inside the zip you downloaded, it should not be bootlooping
I am not sure installing the apk's from the zip works. I was under the impression that you copy the apk's to the system/app folder using something like or with the features of root explorer. and then make sure each copied apk has the same permissions as the the other apps in the folder. Part of Bloodawn's original instructions. I do it that way, and I never have any problems.
