PlayfulGod
Extreme Android User
This is just a repost of req's original thread.
What the hell is this?
It's my build(s) of Cyanogenmod 7.2 Release Candidate 1, ClockWorkMod Recovery 5.0.2.8, and my custom Kernel.
How do I use it?
What works?
What doesn't work?
Yes. You can check my GitHub here.
What did you change recently?
You can always see my latest changes in my commit log here.
Did anybody help you?
Of course. Shabbypenguin was there for me in the beginning. Unforgiven512 provided me a basic device profile to go off of. SuigintouLain provided the original CWM I used to flash my kernel and CWM. hroark13 helped me indirectly by providing his Galaxy Prevail device profile which helped me learn quite a bit, and directly by providing his RIL, Battery Server, and USB Controller code, and nudging me in the right direction for fixing data. Angablade has helped me with many ideas, and eventually we'll be collaborating on the kernel. And last but not least, pressy4pie for helping me test and being a good little monkey.
Great job, can I buy you a beer?
Donate
Can I PM you?
You can, but you'll get a faster response if you join us on IRC. (irc.irondust.net/#admire)
Wait, I want to go back to stock, but your recovery won't let me!?
Don't panic, just install SuigintouLain's original CWM and restore from your nandroid backup you made earlier. (You DID make one, didn't you?)
HERPEDY DURPEDY YOU CAN INSTALL THIS USING CWM HERPDERP
- Developer: requisite0
- Description: CM7 port for the Samsung Admire SCH-R720
- Status: work continues...
How do I use it?
- 1) First make sure you do a nandroid backup.
- 2) Flash my CWM Recovery and Kernel package, then go to Advanced->Reboot recovery..
- 3) Install the latest version of my Cyanogenmod 7.2 ROM.
- 4) (This step is only for non-MetroPCS users) Install the Cricket Wireless or nTelos APN configuration for your data carrier (MetroPCS users can safely skip this step).
- 5) Install the latest gapps (no longer necessary to mount system beforehand) zip.
- 6) (OPTIONAL) Install the overclocked kernel.
- 7) Select Reboot system now and wait at least 10 minutes for the market updates to take effect (connect to wifi first if data connection isn't working)(first boot might take a minute).
What works?
- Wifi
- Bluetooth
- Data
- Texting
- Cell Service
- USB
- Camera (video)
- Data/MMS (in 90% of cases)
What doesn't work?
- Camera (still pictures) - Fast Burst Camera app works from the Play Store.
- Data/MMS (in 10% of cases)
Donate
Can I PM you?
