Root [ROM] CyanogenMod 10 for the LG Motion 4G LGMS770 (l0)
Hey hey
Listen i havent been using this rom for awhile
But if i remember it did not have CNE framework or the policies
While gutting version f I removed all CNE
I found that it seems to help with battery heat and life
i cant say it wont cause issues on this rom but it seems to Stand alone an not requiring anything ekse
So if anybody with flashing knowledge wants to test
make a backup
unzip my file
add the lines from my text to your build.prop
boot into recovery
wipe dalvik and cache
flash the CneFrameworkPolicies.zip
reboot
I hope this helps
but be prepared to flash a backup incase of any issues
as i am not running this rom otherwise i would have tested for you
  • CneFrameworkPolicies.zip
Upvote 0
Hi,
I have a quick question, I live in Ecuador and I'd like to know if this cell phone will work in our networks, here we have
2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 850 / 900 / 1900 / 2100
HSDPA 850 / 900 / 2100 - N7105
as far as I saw a chip similar to the ones for gms, I wonder if this cell will work,
thanks in advance for your help
DISCLAIMER: This is a CUSTOM' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Upvote 0
Hi,
2G NetworkGSM 850 / 900 / 1800 / 1900
3G NetworkHSDPA 850 / 900 / 1900 / 2100
It has no gsm radios so it won't work at all
Upvote 0
Sorry to be a nuisance guys,
I recently flashed the cyanogenmod ROM on my LG Motion.
I also recently found out that I could not use my bluetooth to share files
between my phone and another android. To be more specific,
whenever I try to share a file through a file manager or something of the sort, the bluetooth option would usually show up; however, after flashing cyanogenmod
whenever I try to share a file the bluetooth option does not appear anymore.
Have any of you experienced this bug?
Thank you for the help guys.
Upvote 0
Yes, turning airplane mode on & off fixed the problem.
Thank you for your help.
Regarding recovery - I have both Rom Manager (premium) and nandroid backup installed.
Yesterday when I attempted ROM backup with Rom Manager phone went back to virgin CM10 state.
I am quite ignorant of how all the unlock bootstrap stuff works. Should I look to de-install 2nd-init Recovery or just use nandroid for ROM backup?
Thanks again.
Upvote 0
BEST TECH IN 2023
Smartphones
