Is there anything wrong with the gps file on the 9/03 build can't get it to stop searching or show up.
Upvote
0
what can be flashed sticky has xloud mod
don't unbrick just flash xloud or reflash rom and flash xloud. reflashing rom will wipe /system before flashing. and factory reset will wipe /data dalvic and cache. so unbricking would be a waste of time.
did that too idk wat it is I followed the install process step by step and i have got no where with this rom or bobzhomes.
Very solid ROM.
Only a couple issues.
I switched back to stock as I need the things that don't work.
But the only issues I saw was the korean caller ID, I can't send MMS, [....]
But other than that, very good ROM. I've noticed that it actually runs faster than stock and the battery life is phenomenal so I hope to switch back soon.
Try my liquid smooth rom. Doesnt have near as many issues. Nav bar can be turned off in liquid settings just so ya know.
I also can't use Bluetooth, on calls. Does anyone know a port or a fix for Bluetooth on phone calls.I've clean flashed this twice, & have most of the same problems. Chinese caller ID, can't receive MMS (sends though), purple 1080p video, never finds GPS, and backlight staying on. No issue with sound levels: in-call, notifications, music all fine. I've tried flashing PG's MMS and GPS fixes, no help.
This ROM does indeed run faster than stock, and has good battery life (unless backlight stays on). I hope my third flash is the fix, otherwise it's back to a stock based rom. I will miss all of CM's tweaks, improvements, and general awesomeness.
Can you fix the Data Bars showing 1x. And play store icons are low quality on mobile network
Fix the sauce. LoL. PG, any hints on how to fix bluetooth on calls? Not that I'm very adept at rom modifications. LOLfix the sauce... fix the sauce... fix the sauce!!!
I'm currently running bobzhome cm10. Is there a smoother rom? And is there a kitkat rom for lgms770?
Hey I was just wondering how I can fix this problem I've been having. I flashed the CyanogenMod 10 for the LG Motion 4G about 4-5 days ago. and I been having a problem with my lock screen. I can never get it to turn on the fist 3 times I push the power button. also some times my lock screen turns black but with a glow and after I push the power button it turns on. also last thing when I get calls the screen turns off too. I put the phone next to my ear and it goes off can takes forever to turn on. please help me
I love this CyanogenMod 10 for the LG Motion 4G rom
Thanks for everything please help!
