Since I can't read all the replies above...what are the only things needed to be fixed until CM10 is good for everyday use?
Done unbricking and re-rooting twice. Back to Katana until I figure out how to get data on cm10 .... can't figure it out.
I could not get a drop of data at all. I would even settle for 1x right now
Yeah, it used to take me less than an hour, but I ran my dev laptop into ground when I was doing development for the Ascend and Triumph. Also, did building for the Ubuntu Unity project too. My poor laptop is hanging on by a thread now.
You'll have to pull the source to build. It's quite big (11 gigs, IIRC), so it might take awhile depending on your connection. PG has up-to-date building instructions: https://github.com/playfulgod/android_device_lge_l1m/blob/jellybean/README.md
Then, just drop my hopeful fix per the instructions from my post.
11 gigs hmm,around an two or three hours to download then,I got 50mbps down speeds from Comcast,if I cut Netflix and hulu from my gf,I could download it sooner. How fast do you think my rig would compile this? When I was trying to build akosp for the spirit before giving up it(I realized I was in way over my head) took around 19 min.
your specs again??
I do builds from clobber in about 30m, init repo sync in about 30m on 30M form charter. And I have a AMD 1100T 6x, 16GB RAM, 2x 1TB hdd.
2x2tb HDD,3570k @4.2ghz, gtx5602gb(not sure of this matters),8gb 1800mhz ram.Ubuntu is installed on a laptop 500gb HDD though. I use an ssd, but that's my hackintosh boot.
Loving the data. It rocks. Cm10 ... yes, finally. Can't wait for LTE. And I see PG and others are already working on it
I'm getting data 3g and 1x but when I switched back to my backup I wasn't getting 4g until I went back to cm10 and put network back on lte /cmda/evdo strange but I don't know why it stuck to cdma even when I restore a backup but it work so it's Ok
PG i just noticed I'm running 10-20130518. I'm getting data over 3g.
I thought the last download was on the 5/17 date stamped .... I dont see a 5/18
I've had 3g all night and morning. Awesome.
Tried the hotspot built in to the system and couldn't get that to work even with the help of some hotspot apps ......
hotspot isnt working fully yet.. on my todo list.![]()
Do it now!!!lol joking.
Don't you wish cm10 would have got to this stage this fast on the Esteem?
I got the ROM and I can't go on the Internet on the status bar it says no Internet signal but I can still send Messages and make calls
