Root [ROM][DEV][WIP] CyanogenMod 10 for the LG Spirit 4G
First try to put the keyboard in cause I never had it to restart on me but when u put keyboard in Dont set just power off and boot into recovery wipe just data cache and dalvik cache and fix permission and boot back into system
How about flash the rom first boot into the ROM check to see if another keyboard is available. Then get back to recovery and wipe data cache and dalvic cache and flash the gapps then flash back to the ROM and try the keyboard again . do u have the access to set the keyboard if so then try to install
What kind of keyboard is this u trying to install maybe try another build
That method didnt work :(
I'm prolly going to have to get with a kernel guru to update the kernel and with Dm for some modded display sauce. ;)
Outside of work stuff, the Spirit & Motion are my only projects. ;)
Well pg that's great man I hope you will have some spare time soon to do that stuff :D
I am currently using PG's dirty kernal*
346-2.09GHz.
If its possible to mount/add a GPU kernal to over clock the GPU to a higher frequency than 400MHz
Plz if possible.
LG SPIRIT STILL GOT A BREATHER.
currently working on 4.4 for the spirit.
346-2.09GHz.
Plz if possible.
Are you the one the prophets spoke of ? are you the one to show ours spirits life ? :O
