Root [ROM]|Feb 6 2012| Energy
Hi, this might be a dumb question, but i have a Droid X currently rooted, and i would like to install any of this HTC Sense Roms anything above 3.0 would this be possible, and if so would this one work if not can someone please link where i can find one thanks in advance...
welcome to the forums!!!!!!!!
no do not install this rom!!!!! this is for the evo 4g. you need to go to the right forum to find roms that are suitable for your phone. this could brick your phone!!!
go here: Droid X Android Development - xda-developers for roms for your phone.
I've tried many things to get a2sd to work but nothing:confused: So if you're sdcard is partitioned and you need to use the sd ext for space, then I would recommend holding off on this latest build. Although this 6/28 build is by far the smoothest of them all, a2sd is a must for me to use it as a dd.
I have a 32GB SD card so I never really have much concern for partitioning. If run out of system space I just manually move apps to the SD card.
Yea, I did that as well to see if I could survive with the memory issue and unfortunately 88mb is not enough for me after installing 39 apps. Using native a2sd is not enough when using a large rom, using native a2sd with the Classic rom? Running that rom, I could get away with it without running into memory issues
New update has a2sd working as it should. It now has chopsuey as the kernel but I've had great success with v7. I Someone suggested raising the voltages because caine lowered the kernel by -75 so I raised by 75, so we'll see how that works but it's running nice and smooth right now
Curious question.
Does anyone know if there is an apk for the dock app in this ROM? I love the way it looks.
I am really flashing different roms now (switched to the SIII) to try and learn more. Using the OG EVO as a learning tool now.
p.s. I did learn one big thing about the EVO after I deactivated it. Hint - do not get rid of it or sell it!
Curious question.
not quite sure where the dock is located. i would post this question over on xda.
I recently downloaded the March 2012 version of this Rom cause it was the most recent I could find. Is there a newer version?? I love this Rom, but since I've downloaded it I'm unable to send or receive MMS messages. Any help??
