Root [ROM]|Feb 6 2012| Energy
ocnbrze
DON'T PANIC!!!!!!!!!
another sense 3.5 rom is out. and this is not mine. but it looks really cool. gonna need to give this one a go.
Welcome to the "Energy" ROM thread !
This development thread is for my "Energy" custom firmware series for the EVO !
I build my ROMs with four main goals.
Eye candy ( I want my ROM to look great and for it to all flow together nicely)
Speed !!!
Smoothness, consistency and good aesthetics
Stability through private beta testing before public release
I preconfigure a lot of things in my ROM, because when I flash it on my phone, I want it ready to go. So, the ringtone, sms/email and other notifications to already be set. Doing it this way, makes for a nice ROM that's ready out of the box.
ROM Features
Android 2.3.5 (Gingerbread)
Based on the latest HTC Sense 3.5 leaked ROM (runnymede)
CRT Animation + blue overscroll
Enabled GPU UI rendering
Blue highlights instead of green
Deodexed, zipaligned, tweaked
Extra Quick Settings
Improved SD card read ahead
Busybox + runparts, TitaniumBackup
Zipaligned
Zipaligns apk's at boot
A few HTC Apps removed, like HTC Navigation and some widgets
A lot of junk removed
Stock HTC Kernel
Screenshot by pressing Power and Home
Advanced Power Menu
Updated hosts file for ad removal
A lot more stuff... check the changelog below
Fast... Stable.. and GREAT battery life with the stock HTC kernel
here is the xda link:
http://forum.xda-developers.com/showthread.php?t=1290300
here is some screen shots of it:http://forum.xda-developers.com/showpost.php?p=18145897&postcount=2
So are you saying that WiFi doesn't work in this ROM? If so what is this trick you speak of?
Wifi works fine.:D
If you decide to flash a custom kernel, you will have to do the mount/unmount data trick.
Boot to recovery
Wipe cache
Wipe dalvik cache
Go to mounts, mount data
Flash custom kernel
Go to mounts, unmount data
Reboot phone
Wifi works fine.:D
Boot to recovery
Wipe cache
Wipe dalvik cache
Flash custom kernel
Reboot phone
Ahh, O.K. I gotcha.
Oh man, this is going to be competing with the new supersonic now.
Guess I have something new to play with until it gets released
Anyone know if any of the battery and signal notification mods will work with this ROM? Also why does the "Personalize" button open the internet? Is there anyway to change that?
I have no idea regarding the mods of which you speak.
I understand that if you use a long press on the screen, that you can really personalize from there, and also choose which app you want in the normally personalize button location.
edit: if not, it may be in your settings somewhere to change. I saw that in one rom, it let you decide to choose an app for that spot and then let you pick it.
Its like that for every 3.5 rom. Just hit settings>personalize to personalize
Can someone post the pri/prl on this ROM?
Is it switched to sprint or still running on VZW? I'm hoping to see someone get one of these builds working on sprint towers soon!
i don't believe there's a way to change that right now. Remember that this is the first build from NRG and these things may eventually get resolved
Yup, sounds good...just thought I would ask. So far I am really liking this ROM seems smooth and fast. I have had great battery life so far. I just wish there was a way to 4G working in this ROM instead of having to re-flash a later version when it comes out.
Others may have a different opinion but I personally feel that 4G will never work on these ports until we have a Sprint phone with Sense 3.5. Again, just my opinion:)
Ahh...I understand what your saying, I didn't think about that.
This has been updated!
November 18th, 2011 (11.18.2011)(Sense 3.5)
Second release
ROM tweaked, cleaned, made smaller
Ice Cream Sandwich fonts
Updated to newer Runnymede base
Added RCMixTweaks (thanks RCTeam)
Updated several apps
Made to fit system partition better, more internal storage available for apps
Many little tweaks that I forgot to document
Second release
It runs just as nice as the previous build, highly recommend;)
Update released today!
November 23rd, 2011 (11.23.2011)(Sense 3.5)
Replaced Visual Voicemail with working version. Thanks to johnmclin
Notes, tasks and widgets added in
Beats malfunction fixed (removed!) and SRS, Dolby and equalizers added (yay!)
Added GTalk and Gmail (on data partition so they're uninstallable)
Framework visual mods for cleaner menus and popups
Zipalined and optimized all system packages
Removed shutdown animation to make more space for system packages
Partially fixed HTC Hub
guess my eye's are going, anyone have a good dl link for this, i can't see one anywhere...
EDIT - never mind, i found it.... silly me...
Even better than the 18th build;):)
So those of you that run this...what are the pros and cons? Is it better than newtoroot's version?
It's a themed version of the runnymede and imo, in very good taste!;) Fast for sure but the only problem I've run into is getting a2sd running. For some reason, the normal darktremor's, a2sd reinstall, a2sd cachesd, is not working. But I'm not too concerned about space beacuse I don't have more than 35 apps installed so I'm right around 100mb:( Other than that though, it's definitely worth the flash:)
