I use Go launcher EX.
I don't know if this is relevant: I move every app to SD card.
g60madman suggested that I format the system and update from stock rom, so that's what I will try this time. Let me know if you also have any suggestion. Thanks.
I use go launcher also. I get some small issues that I'm not sure where they are coming from. I think I will look into this (if I stop customizing my build for a day). I may have seen this too.
I would try to use AWD for a couple of days to see if it's related. You shouldn't have to uninstall go launcher, just save the settings if you do. I've been playing with AWD today and I gotta say that it responds better IMO. I just like some of the features of go launcher. That, and it's what I've been using sense FroYo.
Just for a little tease of whats to come in revision 0.3. Is it CM7, is it ICS, or is it MIUI?
Was just thinking...
Is there currently (and if not, could there be) a partial_wakelock called while in call?
Just a thought. May be way off base.Comments?
Nice screenshots, but are you going to style the Google search bar to look like the one in ICS? And the notification area, don't forget that, too! Otherwise, great work. And thanks for responding to and fixing those bugs I reported.Just for a little tease of whats to come in revision 0.3. Is it CM7, is it ICS, or is it MIUI?
No, just a suggestion. That is, if he has the time to do it. If he doesn't it does not really matter.That's a big concern to you?
Yes I do have the ICS search bar set as Mike listed. Sadly the proximity is still not working, was fine all day long after 12 calls and then this evening it started up again after I tested #13. I will be working on it this some more this weekend and do not plan to release until it's fixed!!!
I would start by testing only Betas 1-4, since that's where the changelog says proximity issues were addressed at. What exactly do you mean is the issue with the proximity sensor? The screen turns off or the entire phone shuts down?
g60, mind recompiling the whykernel/oc for me with this stepping table 64,122,245,460, 652,808,1024,1200,14**, 15** up to the highest ? id like to test it.
As far as I remember, I've been updating since TG's final version to Whyzor to g60, the proximity sensor issue has never been fixed. It works for a few times after initial updates, but it goes back again.
The proxitmity sensor issue is:
"when you move [the phone] away from your face during a call, screen stays off."
The screen suppose to back on automatically without having to push power button.
ro.hdmi.enable=false
ro.hdmi.enable=true
Has anyone pulled the Kernel from the latest WIP 2.3.4 (4/29) and tried it in g60's CM7 to see if it enables HDMI?
ofcourse you would aslo have to edit this line in the build.prop
to
It has nothing to do with kernel, there is a lot of code that needs to be edited. I will be implementing wsimon's source for the HDMI in build r0.4. I don't plan to have it working as I need to spend some time with the code but I want to at least get his code into the build.
Here are the directories that need to be edited from the CM7 source code, and here is all the changes wsimon has done
android_vendor_motorola_triumph
android_frameworks_base
android_device_motorola_triumph
android_hardware_msm7k
android_hardware_libhardware
