i think that's a site you were looking at before you closed the browser, then you have YouTube set as the default playing method for the video.
I would reboot, if the problem persists, I would check my Home Page to see what it points to. It could be a bad link. Send your self an email or text with a link so you could follow it.
As a last resort, reflash.
This latest build is awesome! liking the 360 launcher so far. one minor thing i cant figure out is getting the ICS google search. mine is still showing up as ginger bread (white). the ICS black version is very sleek looking. any ideas?
Fantastic work with what you have done! I love this mod so much. One issue though. Every time I load up the camcorder my phone freezes. I kill the camcorder app and try to use my camera and it doesn't work either, but the camera works fine from a fresh reboot.
Again thanks for continuing work on this mod.
I just got my Triumph last week. I really like it, everything people complain about seems to work great on mine, the only complaint I have is battery life.
I just installed CWM and am doing a backup of the stock rom, as soon as that's done, this will be the first ROM I try, thanks for all the hard work everyone has put into this!
LMAO! Funny enough I used too back in 1998-2000, used to have a 1991 g60 Corrado and I used to drive it like a madman and also had a custom logo put on the windshield that said g60 Mad Man. The handle just kind of stuck after that. Sure do miss that car, I always enjoyed watching the spoiler come up at 45 MPH. I chipped it, did the ram air intake and had a smaller pulley installed. Was a fun ride![]()
Interesting thing happened. I uninstalled the latest Google voice update and the search bar reverted to the black ics. Tried updating and it went back to the white search bar
Just posted the new ROM for download, also tested both camera's and also the video. Sorry about that![]()
Finally updated from the last TG Reloaded. I was gonna wait till a camera-working CM9 was available, but that seems to have stagnated for now and I started getting random reboots.
I do have an observation and a request. Observation: I've always been a fan of ADW Launcher so I was sad to see that go. I feel like ADW has more of an AOSP feel and all I want from a launcher is the ability to launch stuff.
Request: Could you possibly include a boot image logo in the next release? My phone still shows the Minimal Triumph logo. I might get confused!
Thanks g60
Do you still have to flash gapps if you're just updating?
I am not 100% sure. Usually when I do an install I do a full format and load the ROM and gapps. Recently I have been just wiping the cache, and the dalvik cache. Then installing ROM and gapps. I would think the gapps would still be there if you are not doing a wipe. I say give a shot and post back![]()
Thanks g60madman for running with the Triumph CM7 ball! I am enjoying the sound fix a lot. Couple minor quirks:
1) No haptic feedback using the "hard" keys, however, soft keys have haptic feedback. Played with CM preference tweaks to no avail.
2) The CM Input setting - Long-press menu settings - does not appear to work. I have mine set to Play Store but a long press of the menu key does not do anything.
3) Cannot change icon logos on home pages. I could not find any documentaion of the 360 launcher (which I like btw, thanks). For example my Google Play Music icon is the same as the stock music icon.
Thanks again.
You bet
1) I take it you mean hard keys on the physical phone and the soft keys as the screen. Both mine are working after I went into 360 preferences < Screen Lock Settings after closing out and holding down the home button it started working. Looks to be a bug with 360 Launcher
2, 3) I just released 0.4 which updated 360 Launcher to version 2.3 which added the ability to edit icons, and fixed the home button. When you long press on the icon the option is "rename icon". I was able to change my Pandora icon picture with out any problems, along with the long press for the home button.
EDIT: Also MikeRL is working on some documentation for the phone, from a CM7 stance and also the new launcher.
Now to figure out how to get the long-press for Menu to work...
