Root [ROM][FINAL] CM7 7.2 RC1 - g60 style [7.11.12]
Sorry if this is bothersome but I am having an issue. The audio is very low when listening to music by headphones or speakers. Pausing it and unpausing does not seem to work anymore. Is it just me or...? Other than that this rom is amazing. I know this is not the fault of the rom but the phone itself.
I updated to 0.4 tonight via the usual method (wipe both caches and then flash).
In Camera, the rear camera works fine in video or for photos. However, if I switch to the front camera and then change to Video the screen freezes or goes black and then eventually I will get the message "Activity Camcorder (in application Camera) is not responding" and can Wait or Force Close.
Wait does nothing, and if I Force Close and then subsequently try to launch Camera again I get the message "Camera error - Cannot connect to camera". Only a reboot fixes the issue.
I just flashed r04 and have 2 issues, everything else works perfect:
1. The already reported front camera switch to video mode freeze
2. If I use a headset to talk, 1-2 sec after the long press on the 3 way button to hang up the call the music starts playing (loud). Sometimes it stops after 1-2 sec, other times I have to press again to stop it. I never had this problem with the stock ROM but the TG-reloaded final has the same issue and I guess it continued to propagate to the g60 builds.
Awesome job g60madman! Thank you for helping us!
Not sure how you guys are getting this, mine works fine.
Go to the camera. switch from back camera to front camera. now use the slider to change from camera to video. my phone freezes at this point and the lower part that contains the camera/video slider and shortcut to gallery turns grey. then i get an option to wait or force close. nothing happens if you wait. if you FC and then try to open the camera you get this error: "Activity Camcorder (in application Camera) is not responding". Reboot fixes the problem.
I can replicate this anytime.
I see what I did. I went from back cam>front>back and then slid it to camcorder. It did freeze when I switched it when it was on front cam.
Never tried it before, but it happened to me. I'm on my build from g60's code, with some of my mods. I think I last sync'ed when r0.2 came out.
just noticed something on both my phone and my wife's phone (both running this rom). vibrate does not work. anyone else notice this?
Interesting, vibrate works, but not when receiving sms. I just double checked all settings (in sound, within app, actually in vibrate mode) still nothing. However, I believe the 360 launcher may have fixed some touch screen freeze ups that I was having in ADW. My phone's touchscreen would hang up randomly, but 2 days into 360, no freezing! Hope the vibrate bug (or my stupidity) is figured out! Cheers!
Need help because i downloaded this and flashed it.
once i flashed it it wouldnt boot up....
please help
i was on wyzor's final final cm7 rom
First I wanna say THANK YOU SIXTY!!!
I never thought the in call black screen proximity issue would EVER get fixed..but you did it!
Now to everyone else: please take my opinion for what it's worth. (Perhaps nothing). Please do a COMPLETE factory reset, and flash this rom in its virgin state. I know it's a pain in the ass, especially if you have your settings "just right". I had a couple of bugs left after release #4 that disappeared after a FULL wipe and flash (including gapps). This route may also refine the bug reports to determine user vs. Rom issues.
Like I said...just my opinion.
I'm starting on the FAQ now. The problem with me answering questions is that many people here seem to live in a different time zone than me, so it seems like I take a while to respond.
I'm interested in trying out this ROM, I'd be updating from Whyzor's cm7. If I want to stay with ADW launcher after moving to g60madman's, I can just install it and then select it as the default upon hitting my home key?
I tried g60s for a moment but the 360 launcher scared me so I restored to the Whyzor build.
Don't be scared it's a great launcher, it just starts in Chinese text but it's about 95% English. Then you can follow the wiki I have on the first page to setup MIUI or ICS.
However if want the 360 out you can open the g60.zip ROM and then delete the 360.apk located in system/apps. Once you are all setup you can download ADW again.
I am having same camera issue any updates on a fix??
danger will robinson! you need to have a launcher in the rom for the phone will lock after the setup wizard
