So far so good. Got it up and running again. Adding apps very gradually. Have rebooted myself a couple of times and no issues. But when I reboot the lockscreen does not come up. Should that be the case? I do get a lockscreen I lock the phone but not on a reboot. Just haven't seen that before.
I might as well. If people understand more properly what part of android holds what, they won't wind up bricking their phone so often. Remember people, do not format anything besides what you are told to format! I am going to add more sections to the FAQ on how to upgrade and how to do a fresh wipe. I must have forgotten some obvious stuff.Hey, do you want to add this to your FAQ? It gives a good explanation of the file system used on Android phones. That way people can have a deeper understanding on what they are doing when the clear cache, data, or format system.
Ok g60 boot screen, and no corrado? I am disappoint.
So far still working well! This rom and the new b kernel seem to being working well now. Made another backup for myself just in case but do far I am liking this setup!
b_randon14 said:CM7 version has not been updated. It is way behind the current CM7 kernels, and I'm not sure it will even boot the current build of CM7. I've got to put alot of work into the CM7 kernel in order to get it updated. Thanks for understanding!
Hey g60, when I build, should it still show r 0.4? I did a make clean and am trying to build again. I just wanted to know what to expect when it's done. And post in case anybody else wanted to know.
Does anyone have some recommended overclock and underclock settings?
You might want to add the front camcorder force close problem to the known issues on the first post if it can't / won't be fixed.
