steveokinevo
Don't use the AOSP Lockscreen if you are.
Which one is that? That may be the problem. Im using ripple at the moment
How can I get different keyboards on here? I want one that corrects my spelling mistakes
I see you can't keep up![]()
Is there no place to disable proximity sensor in the menus? Or am I just not seeing it?
Anybody know why I always have to use 2 locker screens to unlock my phone? I disabled multilocker but can't change the default locker to what I want and dont wanna deal with 2 lock screens
Just remove it with Titanium Backup or ROM Toolbox and wipe dalvik cache in recovery afterwards.
I'm on GB27.. didn't know I can switch over to GC01?
GC01 is just the Boost labeled version of the same ROM. Most custom ROMs are based on Sprint versions but will run just fine on Boost. If you are running stock GB27 then changing to GC01 will only change the bloat app labeling (sprint zone to boost zone etc)
If you want to use Multi Locker go to System Settings/Lock Screen and switch it from swipe to none. Also go to System Settings/Security/Device Administrators and make Multi Locker an Administrator.How can I have just one locker and still be able to customize?
Why wouldn't gb27 simply work for tank like everybody else?
