PlayfulGod
Extreme Android User
DISCLAIMER: This is a MODDED' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, GingerSteem Extreme!!! It has been debloated, deodexed, and tweaked for better performance and speed.
- Version: 1.1
- Developer: mtmichaelson - GingerSteem - Please dont forget to toss mt some cheddar too if you donating for this.
- Developer: PlayfulGod - GingerSteem Extreme
- Description: Modified Stock ROM for the LG Esteem M910
What is this?
This is a very lightweight ROM built both for speed and stability. This ROM is based off of the LG's ZVB update to Gingerbread. It is fully deodexed, and debloated. Swype has also been changed to the 3.26 Beta. A few items have been replaced with AOSP versions to increase speed and decrease size. Also included is the appwidgetpicker to clean that up.
Changelog
- v. 1.0 Initial Release
- Based off of ZVB Gingerbread 2.3.4
- Deodexed
- Zipaligned
- Heavily Debloated
- ADW Launcher
- Astro File Explorer
- ROM Toolbox - overclocking/underclocking can be set with this app among many other features.
- Droid RAZR Boot Animation & sound
- AOSP Lockscreen
- Accurate Battery Mod
- CRT Screen Shut Off
- Swype Beta 3.26
- Fixed Recovery Not Sticking
- Build.prop Tweaks
- Init.d tweaks
- Battey Charging Animation
- V6 SuperCharger Tweak
- Loopy Smoothness Tweak
- Blocked All CIQ Logs From Carrier and Google (Requires Reboot After Install)
- Other Tweaks for Speed and Battery Life
- Plague Extreme oc'd to 2Ghz max
- ADWLauncher - CM7 version
- GingerFusion Theme added.
- HDMI out fixed. thx to mt for source.
Plague Kernel:
- Overclocked to 2Ghz
- Underclock settings added as well
- Interactive governor added
- Smartass2 governor added
- Tun.ko support
- CIFS support
- SDCard Read Ahead Speed Tweak
Screenshots
How do I install this?
- 1.) Download the .zip & copy to phone or sdcard (make sure 4g is enabled if dl'd from phone).
- 2.) Zip can be installed from either internal or external sd in CWM
- 3.) MAKE A BACKUP
- 4.) WIPE DATA/FACTORY RESET!!! (You do not need to wipe if already on GingerSteem!)
- 5.) Go to install zip from sdcard > Choose zip from sdcard
- 6.) Select GSE-1.5-signed.zip
- 7.) Do not wipe data after flashing!!!
- 8.) Reboot!
- 9.) To Block Carrier Logging Requires Reboot After Initial Boot
Downloads
- GSE v1.5: GSE-1.5-signed.zip
- Available through ROM Manager now too!!!!
Special Thanks!!!
- Dev's
- mtmichaelson - help and assistance with development, and the use of his ROM as a base for mine.
- Testers - they all deserve major props for testing, bricking phones, patience, and understanding I/we have a life outside of Android.
- EvoImage
- youngnex
- vistor831
Nice work PG
